Does the parallel port itself determine what the voltage of High and Low logic signals are? My parallel in my PC is putting out 3.4-3.5V on the High signal and .3 on the low. Those are not working out well with my drive. It would help me a lot if the 3.5V High was more like 4V or up. Will a different parallel port operate differently (and perhaps give me a stronger High signal) or are they all the same? How do PCI slot parallel ports generally differ from the built in ones. Does the PCI slot offer any advantages?
