Material Selection in Work offsets
Hey,
It's been a long time since i've gotten to work with a TM-1 and at one point I was mediocore but I'm back to zero now. I know on my TM-1 & TL-1 when I go to set a work offset I can choose a material and then when I run IPS it should create values for spindle speed and feed based on that in combination with the material type selected for the cutter.
I set my tool offset and selected the material as Carbide, in my work offset I selected SS-1. When i go to generate the IPS code though it comes out with feeds and speeds set as 0. What am I overlooking or what setting do I not have right?
I know the values Haas gives back aren't perfect but because I'm young and doing prototyping I have the time to check values online, through MasterCAM, the Machinery Handbook and through IPS to give me Idea of how I should be running the machine since I rarely see the same material twice in any give month.
-JWB
--We Ain't Building Pianos (TCNJ Baja 2008)
