585,931 active members*
5,190 visitors online*
Thread: Facing Macro
    Dec 2008
    69
    Facing Macro
    I use this a lot for quick stuff. Thought it might be useful to someone.
    Code:
    O09010 (FACING)
    (FLAGS)
    (REVERSE LAST PASS)
    #110= 1
    (VARIABLES)
    (FEED RATE) #9= 32.
    (TOOL DIA) #101= 2.
    (Y  DIST.)  #102= 8.5
    (X  DIST.)  #103= 12.5
    (RADIAL E) #104= #101 * 0.8
    (SETUP VARS)
    #105= #103 * -1
    #106= ROUND[ #102 / #104 ]
    #107= [ #106 * #104 ] * -1
    IF [ [ #102 MOD #104 ] GT 0 ] GOTO300
    (RPM)
    N50 M03 S880
    WHILE [ #106 GE 1 ] DO1
    M97 P100
    IF [ [ #106 EQ 3 ] AND [ #110 EQ 1 ] ] GOTO200
    #106= #106 - 1
    END1
    M30
    N100 G91 G01 X#105 F#9
    G00 Z1.
    X#103 Y#104
    G01 Z-1. F#9
    M99
    N200 G91 G01 X#105 F#9
    G00 Z1.
    Y#104
    G01 Z-1. F#9
    G01 X#103 F#9
    GOTO400
    N300 #106= #106 + 1
    GOTO50
    N400 G00 Z3.
    Y#107
    G01 Z-3.
    M30
    Dec 2008
    69
    V1.1
    Been a while since I had to think through a programming problem and I ****ed up the loops so it went to the wrong position without the reverse direction of last pass flag set.
    Probably going to set it up to use SFM and FPT rather than RPM and FR later.
    Code:
    O09010 (G200 - FACING)
    (FLAGS)
    (REVERSE LAST PASS)
    #110= 0
    (VARIABLES)
    (FEED RATE) #9= 32.
    (TOOL DIA) #101= 2.
    (Y DIST.) #102= 8.5
    (X RETN.) #104= #103 * -1
    (AXIAL E.) #105= #101 * 0.8
    (# PASSES) #106= ROUND[ #102 / #105 ] - 1
    (RETN. Y.) #107= [ #106 * #105 ] * -1
    (IF Y DISTANCE REMAINDER IS GREATER THAN ZERO)
    (ADD A PASS)
    (START SPINDLE)
    N50 M03 S880
    (WHILE PASSES IS GREATER THAN OR EQUAL TO ONE)
    (CLIMB ACROSS SURFACE)
    M97 P100
    #106= #106 - 1
    END1
    M30
    (SUB)
    (CLIMB PASS)
    N100 G91 G01 X#104 F#9
    (IF PASSES IS EQUAL TO TWO AND RLP FLAG IS SET)
    IF [ [ #106 EQ 2 ] AND [ #110 EQ 1 ] ] GOTO200
    (IF PASSES IS EQUAL TO ONE RETURN TO HOME POSITION)
    IF [ #106 EQ 1 ] GOTO400
    G00 Z1.
    X#103 Y#105
    G01 Z-1. F#9
    M99
    (SUB)
    (REVERSE DIRECTION OF LAST PASS)
    N200 G00 Z1.
    Y#105
    G01 Z-1. F#9
    G01 X#103 F#9
    GOTO400
    (FUNCTION)
    (INCREMENT PASSES)
    N300 #106= #106 + 1
    GOTO50
    (SUB)
    (RETURN TO START POS)
    N400 G00 Z3.
    IF [ #110 EQ 0 ] THEN X#103 Y#107
    IF [ #110 EQ 1 ] THEN Y#107
    G01 Z-3.
    M30
    Jun 2009
    65
    Nice Job!!! I barely know what I'm doing when it comes to custom Macros, but I really wanna learn more!
    Might try that out next week when I get a chance.
    Thanks for sharing :cheers:
    Dec 2008
    69
    If you're using a Haas there is a programming reference in the back of their book.
    The standard that Fanuc based controls are using I think is RS274D but there is also RS274-NGC and ISO 6983.
  1. Replies: 2
    Last Post: 03-27-2009, 09:15 PM
  2. V22 Facing ?'s
    By bink in forum BobCad-Cam
    Last Post: 02-16-2009, 12:22 AM
  3. cylinder facing
    By pp-TG in forum MetalWork Discussion
    Last Post: 01-30-2009, 03:53 PM
  4. Convert Fanuc Macro to Fadal Macro
    By bfoster59 in forum Fadal
    Last Post: 11-09-2007, 06:41 AM
  5. Facing
    By impact in forum MetalWork Discussion
    Last Post: 02-23-2006, 03:24 AM
