Originally Posted by
rthorntn
Hi CNC'ers,
Please help if you can.
Kit is:
Chinese CNC 6040 with VFD
The crap controller replaced with GeckoDrive G540 kit
6mm 3 Flute Carbide Endmills HRC50
PC with printer port running EMC2
Material is 3mm aluminium sheet
I want to start by cutting case panels that have various sizes and shapes of holes cut in the sheet, for example in a 300mm x 300mm sheet, cut 4 panels of 250mm x 50mm and in each panel cut some other assorted holes for vents and fans and ports.
So I need CAD and CAM for a beginner that will quickly let me do this.
Your recommendations would be much appreciated, there is so much on offer, I scoured the list and found a lot of recommendations.
A combined CAD/CAM solution would be preferred, maximum budget is $200USD.
My needs are simple, would there be a good free CAD/CAM solution?
Thanks.
Richard
