586,000 active members*
4,834 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > VCE-750 with BLDC Servo - X Axis Servo fault
Results 1 to 7 of 7
    Dec 2005
    5
    Hello my Friends
    I'm Daniel from Germany. I have buyed HAAS VCE-750 new in 1996, without X Axis BLDC servo. I have two questions:
    - where can i buy such a Servo
    - can I replace all servos with another AC servos and Drivers ? i think it is possible but i need the control signals from Control System to servo amplifer. What signals are they ?
    Best Regards
    Daniel
    P.S.
    Sorry for my english
    Jul 2009
    80
    Daniel
    HAAS uses Yaskawa motors
    and servo-amps are HAAS made
    Robby
    Dec 2005
    5
    Hallo Robby
    thx for Your Answer. Do You know what signals use HAAS to control the servo amps ? Is it +/-10V or Step/Dir or maybe own protocol from Haas ?
    Daniel
    Jul 2009
    80
    Hey Dan
    Don't know exactly, but if I compare with Manual Pulse Generator
    It uses +/- 5VDC
    Signals come directly from MoCon Board
    Robby
    Dec 2005
    5
    If it is so, then i will replace the DC Motors and amps with AC servo system with Analog Input. Know any one on which PIN's is the Control Signal from Control system ? Maybe any one have a Manual ?
    Daniel
    Jul 2009
    80
    Dan
    I got confused, when you write BL, for HAAS means brushless!
    So I thought you had AC Motors.
    brush motors work with 160 VDC and power is generated in Board on right side Of servo-drives.
    With rainbow cables which happen to be voltage to board circuit and control is managed by Motif Board.
    Still dont have configuration
    I will look in my notes to see if find something
    Robby
    Dec 2005
    5
    Robby
    I have BLDC so Brushless DC servos. One servo is fault and as i know new motor is very expensive. So my Idea was to replace it with Universal AC Servomotors and AC Amps. Then i will need new transformer and i have to connect some I/O to control system from HAAS. But the most important info is what signal do i bekome from CNC Control to control the servos .
    Thank You for Your Help
    Daniel
  1. Replies: 8
    Last Post: 09-09-2011, 02:01 PM
  2. SERVO DRIVE FAULT ON AXIS S BMC 40
    By tallenttoolroom in forum HURCO
    Last Post: 08-30-2011, 09:59 PM
  3. Searching for a BLDC or AC servo Controller
    By irxplod in forum Open Source Controller Boards
    Last Post: 05-13-2011, 09:27 PM
  4. Replies: 4
    Last Post: 11-15-2010, 04:37 AM
  5. BLDC servo amplifier
    By JBViklund in forum CNC Machine Related Electronics
    Last Post: 02-27-2010, 01:19 AM
