586,024 active members*
4,299 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Stock error mx4 and 5
Page 1 of 2 12
Results 1 to 20 of 21
    Oct 2011
    Hi guys
    I am having issues with stock in x4 and 5. I create a rough pass on an ID and it seems fine but it doesn't update the stock correctly. It is leaving stock where the toolpath clearly goes right thru. this causes retract and toolpath issues on operations that follow
    Has anyone encountered this? or have any ideas what might be wrong?
    thanks in advance for any insight its really appreciated!
    I have done updates mu3 for x4 and mu1 for x5
    Oct 2011
    This is a lathe part in case there is any confusion.
    As you can see the toolpath goes straight thru the stock but it doesn't update?? WTF?
    Nov 2009
    45
    Quote Originally Posted by Avsfan135 View Post
    Is the little red arrow in the operations manager above that operation? If it is it will not update. Drag it below that operation and it should. I'm not positive on this one, but feeling lucky.
    Oct 2011
    No the arrow is below the operation.
    The stock update worked for the chamfer and first section of the ID I think it's getting confused crossing that I'd groove.
    But this is just one example I'm constantly having strange stuff happen with the stock. Either not updating or sometimes just appearing out of nowhere. I've even had it give me the collision with stock warning when the stick is deleted.
    Oct 2011
    Quote Originally Posted by dtm View Post
    I do appreciate the reply. Thank you.
    I really think the error has to do with my computer somehow.
    Apr 2003
    3578
    share the file you are showing and I will run it on my X5 if you like or if you send me the X4 file I can run it thru both and review.
    Cadcam
    Oct 2011
    Quote Originally Posted by cadcam View Post
    I would really appreciate that! Thank you! I'll send it tomorrow morning.
    Apr 2003
    3578
    ok will look for it.
    Cadcam
    Apr 2003
    3578
    review picture and then turn off Use Margins regen then turn back on.
    This is a issue to send to QC and I will take care of that.
    Cadcam
    Oct 2011
    Its not working for me.. I deleted stock, regen turn stock back on regen its still not right. Then I turned off use margins did and back on. No luck..
    Maybe its a settings issue?? Graphics? crappy computer? (its not that crappy tho its actually fairly new)
    I really appreciate your help!
    Also what do you mean by review picture?
    Apr 2003
    3578
    Ok give me speacs on the computer you are using.
    As for review picture showing that it is now correct and were was the check box for (Use Margins ).
    I did this on X5 Do you want me to do the same test on X4? it will be a diffrent computer to?
    Cadcam
    Oct 2011
    Ok I'll get those specs from the IT guy (he "built" it) and get back to you.
    As far as running it through X4 I don't think it is necessary I am moving more toward using only X5 anyhow
    Oct 2011
    machine specs
    HP Compaq dx2400 microtower
    pentium dual core
    [email protected] GHz
    2.6 GHz, 2.99 gb of RAM
    Oct 2011
    if there is anything else you need let me know and I'll get it to ya
    Apr 2003
    3578
    Yes sir what is the Video card that would be it.
    Cadcam
    Oct 2011
    Ok the card is Intel G33/31 express chipset family
    I can get more info if you need
    Apr 2003
    3578
    ok a huge issue is the onboard video that sharse the ram. this computer after doing my home work is not for doing Cadcam work but for small bussness of duties. See if there is at least an option to add a better video card. this box may not.
    Cadcam
    Oct 2011
    I can change the video card. Do you have a suggestion? What works best with mastercam?
    Apr 2003
    3578
    go with a Quadro 1700 or 1800 card not to costly but made for this.
    Cadcam
    Oct 2011
    Ok I'll get that card.
    I just want to say thank you so much for all of your help. I really really appreciate it!
Page 1 of 2 12
  1. Move Through Stock in Error
    By aussiegazza in forum BobCad-Cam
    Last Post: 07-18-2011, 09:48 AM
  2. stock define error
    By Rik H in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-06-2011, 08:13 AM
  3. Error 414 Z axis error detect- servo alarm
    By andywids in forum Fanuc
    Last Post: 07-09-2009, 04:33 PM
  4. Error 414 Z-axis error detect servo alarm
    By andywids in forum Uncategorised MetalWorking Machines
    Last Post: 07-09-2009, 03:56 PM
  5. head stock and tail stock chucks
    By mocnc in forum DIY CNC Router Table Machines
    Last Post: 10-20-2004, 03:16 AM
