585,906 active members*
3,746 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Strange behavior with VFD
    Dec 2010
    634
    I'm using a gecko g540 to control a hitachi WJ200 vfd. I'm using the 0-10v signal for speed and output 1 for run control. Everything was working fine but today I came down to machine some parts and unplugged a USB cable connecting the hitachi to the compute, just because i didn't think it necessaryr. When I went to run my program, the spindle didn't start up and I almost wrecked a bit.
    I figured it t on accident when I started up pro drive next, hitachi's programming software to see if any settings mysteriously changed on me. When I plugged the USB cable back in, the spindle started up!
    I'm thinking this must be a grounding issue because there's no control software running on the pc to run the vfd.
    My connections between the gecko are
    GND, 10v and signal to pins L, H and O, Output one to smart pin 1.
    Any ideas as to what may be wrong?
    -Andy B.
    http://www.birkonium.com CNC for Luthiers and Industry http://banduramaker.blogspot.com
    Dec 2010
    634
    C'mon - no one?
    -Andy B.
    May 2005
    925
    charge pump enabled?
    ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
    Dec 2010
    634
    I fixed it, just forgot to post on this thread.
    Turns out that the grounds on the control voltage and the start pins are not shared on either the VFD or the Gecko. When I tied the VFD smart pin ground to the Gecko ground it started working properly.
    -Andy B.
  1. NM-200 - strange behavior?
    By kvom in forum Novakon
    Last Post: 07-29-2011, 12:14 AM
  2. NM-200 - strange behavior?
    Last Post: 05-24-2011, 02:28 PM
  3. Strange Behavior.
    By riveracnc in forum Mach Software (ArtSoft software)
    Last Post: 11-29-2008, 01:54 AM
  4. Milltronics strange behavior
    By KBHone in forum Milltronics
    Last Post: 12-10-2007, 12:00 AM
  5. Strange circle behavior, 151B control
    By swarf_rat in forum Bridgeport / Hardinge Mills
    Last Post: 07-16-2007, 03:08 AM
