I get the rails and ballscrews and make the machine to those sizes. Remember you loose around 200mm travel in the rails on X axis and 150 in the Y axis rails. This is the connections between the axes.
I haven't kept any photos of my previous builds but they will be on this forum. There are good examples of table design in other threads and I would expect 6 legs with adjusting feet for a machine of that size. A welded steel table will result in some distortion of the steel so allow for shimming between the table and your T slot or some other means to get it flat.
It might be better for you to start a build thread on here as you should get plenty of good advice from the forum.
cheers,
Rod
Perth, Western Australia
