585,759 active members*
3,910 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > 1/8" 2 flute and "O" feed/speed/rpm
    Feb 2010
    3447
    Talking 1/8" 2 flute and "O" feed/speed/rpm
    Would like to make a single .063" cut (all the way through) in 5052 aluminum sheet. For best tool life what ballpark numbers am i lookin at?
    G wizard is telling me:
    cut depth: .063"
    cut width: .125"
    RPM (24,000)
    Feed rate: 36IPM
    Surface speed: 785
    chipload .0015
    deflection .0012"
    horsepower: .0227
    MRR (CI) .2835
    What is the proper chipload? Most likely bendable aluminum like 5052. I still need to hook up my koolmist system and air blaster.
    Thanks for the help.
    Jul 2005
    12177
    A chipload of 0.0015 for a 1/8" cutter seems a bit high. The rule of thumb that I use is 2% of the diameter for cutters above 1/2" and 1% or less for smaller cutters, a 1/8" cutter would fall into the "or less" region. I would not try greater than 0.001" and with 5052 I would keep well into the "or less" because this alloy is a bit gummy to machine.
    Feb 2010
    3447
    recalculated it as you suggested .001" chipload.
    says 24,000 rpm @ 24ipm now with a surface speed of 785.
    I forgot to mention these are for a onsrud "O" flute cutter.
    tool deflection of .0003"
    I will have to try this on out. Hopefully kool mist will work well.
    Aug 2008
    292
    stickout
    Quote Originally Posted by diyengineer View Post
    tool deflection based on end mill flute length and amount end mill is sticking out of the collet. is sticking of 2x more then normal then it is 2x2x2 less rigid
    a stub length is around 1.5x dia in length, a regular length closer to 2-3x dia in length. in general if cutting through sheet material a stub length is better. ......also the sheet material should be held down with vacuum or double sided tape to plywood. i have seen partially cut sheet curl up as it is being cut causing end mill problems
    Sounds to me like your feedrate is too low, and rpm too high. Find an Onsrud bit that matches what you're using, and compare to their charts. most seem to want .02-.03 chip load.
    Aluminum Chipload Chart by Onsrud Cutter | | LMT Onsrud
