585,763 active members*
4,191 visitors online*
Page 1 of 2 12
Results 1 to 20 of 22
    Mar 2011
    lost Data hitachi seiki HT 20
    I have a 2nd hand HITEC-TURN HT20, Serial N°22245, Constructed 14/10/1986, which I bought recently. As it didn’t work since long time, it lost all data table. With the help of friend I found some of them. But the data specific to “HITACHI”, DATA TABLE, DATA CONTROL, DATA N° D0000-D0002-D0010-D0018-D0026-D0034-D0042-D0050-D0058-D0066-D0074. All of this parameters contain 7 Bits. This DATA concern spindle speeds and tool post rotation.
    And the DATA for PC counter and PC keep relay.
    Please, If anybody have this type of machine, help me please.
    Oct 2007
    179
    Hi are you looking for parameters for the Fanuc side or the Hitachi PMC side? Does it have a Micon 8 controller on the cabinet door?
    John
    Mar 2011
    what's Micon 8 please?
    parameters for the Hitachi PMC side.
    Thses parameters concern spindle speeds.
    Oct 2007
    179
    Hi the Micon 8 is an Hitachi PMC found on lathes of this age. Is it a Fanuc 6TB controller?
    John
    Mar 2011
    Quote Originally Posted by cnc-it View Post
    John
    Hi John,
    I don’t know how can I fin dit , but my CN is Fanuc 10T.
    Mar 2011
    Angry
    Hi all,
    My real problem is when I program M03 S4000; machine t urn only 1022 RPM.
    Same for any other spindle speed. Only 1/3 of the given speed realized.
    And I don’t have an operator’s manual for programming this machine.
    System runs with FANUC 10 TE-F
    Year 1986 October. TYPE; TTV-32DKL
    Find my front panel as an attachment file.
    Regards.
    Dec 2006
    58
    Hi
    i have the same control on the hitachi Fanuc 10 te f that i run. try m41 before the g96 command, this is high gear / range. the machine will default to m40, low gear / range. m40, m41 MUST be commanded by you. hope this helps. enjoy the day
    ps, do you have FAPT on this machine?
    Mar 2011
    Hi Gerry,
    Thanks for the help. I’ll try it in this evening.
    Yes I do have FAPT on this machine. But it doesn’t work also.
    There is an alarm “parity error”
    Please tell me do you have the programming manual for this machine?
    I tried the drilling cycle with G74 as;
    G74 R.3 Z-20. Q1500 F.08; but it doesn’t.
    Regaeds.:cheers:
    Aug 2011
    2517
    I've been using FAPT/CAPS etc for around 20 years. If you need to know anything about FAPT programming just ask.....
    G74 format is...
    G74 Z (end point in Z axis) K (peck amount) F (feed rate)
    there are other items on the G74 line but they can be omitted when peck drilling.
    Mar 2011
    Smile
    Hi Gerry,
    I try M41 and M40 on my machine. Yes, you are correct about these two codes.
    Machine by default turn on M41 mode.
    I explain it to my friend how helped me to get the machine done.
    So he shows me on the screen the path, to copy from another machine, as follow;
    • Click on NC/PC button
    • PCPRM bottom screen
    • DATA bottom screen
    • You find the page, DATA TABLE CONTROL DATA
    From D000 to D0074.
    Please be kind to copy these and send me.
    This photo show you the page.
    Regards.
    Mar 2011
    Smile
    Thanks for the help. I’ll try it tomorrow.
    Regards
    Dec 2006
    58
    hitachi 10t f
    Bon Jour
    i will have a look this weekend. hold the BS key as you power up, it should get rid of this parity error, we had the same problem. i will look for the parameters that were down loaded and send them to you. hope this helps.
    Mar 2011
    Question
    Quote Originally Posted by fordav11 View Post
    G74 format is...
    Hi, I tried it this morning but doesn't work. tool post move only five tenths and repeat in the same position.
    is there G74 in two lines?
    mean in first line G74 and K (peck amount) and the second line G74 Z (end point in Z axis) F (feed rate)
    Mar 2011
    Question
    Quote Originally Posted by Capt Crunch View Post
    Bon Jour
    I think you are my only rescue.
    I’m waiting for your precious help.
    This morning I tried to remove 1mm pass with stock removing cycle. But the machine has not power enough to do so. Spindle stopped. I think all this problems link to parameters problem.
    Regards
    Aug 2011
    2517
    Quote Originally Posted by emind View Post
    No, 10-series uses only 1 line. 2-line fixed cycles was first introduced in Fanuc 16-series.
    The fact that it works to some degree means it's correct.
    There are dozens of parameters relating to fixed cycles. Most likely some of them are not correct.
    Fixed cycle parameters are from 5100 to 5199.
    Please list all of your parameters here in this above range and I can help to correct them.
    If they are all 0 then that's where your problems lie.....
    I personally think you won't fix it (i.e. all of your problems) with just a few specific parameter changes.
    You really need a full dump of the entire parameter range from a similar Hitachi machine with 10T control.
    Mar 2011
    Question
    I send you all parameters found in my machine.
    please let me know were is the error.
    Thanks and best regards
    *%(HITECTURN)* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * % N1033P0
    N0P00001000 N1034P0
    N3P00000000 N1035P0
    N10P00000000* N1200P00000000*
    N11P00000001* N1220A1P292000A2P334890A3P0A4P0
    N12A1P00000000A2P00000000A3P00000000A4P00000000 N1221A1P0A2P0A3P0A4P0
    N20P1 N1222A1P0A2P0A3P0A4P0
    N21P1 N1223A1P0A2P0A3P0A4P0
    N22P1 N1224A1P0A2P0A3P0A4P0
    N23P1 N1225A1P0A2P0A3P0A4P0
    N100P3118690* N1226A1P0A2P0A3P0A4P0
    N101P25776* N1240A1P0A2P0A3P0A4P0
    N102P1000782* N1241A1P0A2P0A3P0A4P0
    N103P45616* N1242A1P0A2P0A3P0A4P0
    N104P565578 N1243A1P0A2P0A3P0A4P0
    N105P0* N1244A1P0A2P0A3P0A4P0
    N106P0* N1245A1P0A2P0A3P0A4P0
    N107P372081 N1260A1P0A2P0A3P0A4P0
    N1000P00000011* N1400P00000011*
    N1001P00000000* N1401P00001000*
    N1002P00000000* N1402P00000000*
    N1004A1P00000000A2P00000000A3P00000000A4P00000000 N1410P1000*
    N1005A1P00001000A2P00001000A3P00000000A4P00000000 N1411P0
    N1006A1P00001000A2P00000000A3P00000000A4P00000000 N1412P25*
    N1020A1P88A2P90A3P0A4P0 N1413P0
    N1022A1P1A2P3A3P0A4P0 N1414P100
    N1023A1P1A2P2A3P0A4P0 N1415P0
    N1024A1P0A2P0A3P0A4P0 N1416P0
    N1030P67* N1420A1P1000A2P1200A3P0A4P0
    N1031P1 N1421A1P400A2P600A3P0A4P0
    N1032P0 N1422A1P500A2P500A3P0A4P0
    N1423A1P1000A2P1000A3P0A4P0 N1827A1P20A2P20A3P0A4P0
    N1424A1P0A2P0A3P0A4P0 N1828A1P12000A2P8000A3P0A4P0*
    N1425A1P120A2P120A3P0A4P0 N1829A1P500A2P500A3P0A4P0
    N1426P0 N1830A1P500A2P500A3P0A4P0
    N1427A1P0A2P0A3P0A4P0 N1831A1P0A2P0A3P0A4P0
    N1428P0 N1832A1P6000A2P4000A3P0A4P0
    N1471A1P0A2P0A3P0A4P0 N1833A1P0A2P0A3P0A4P0
    N1472A1P0A2P0A3P0A4P0 N1834A1P7A2P-8A3P0A4P0*
    N1493P0 N1835A1P2500A2P2000A3P0A4P0
    N1600A1P00000000A2P00000000A3P00000000A4P00000000 N1850A1P-3672A2P-2216A3P0A4P0
    N1620A1P50A2P100A3P0A4P0* N1851A1P7A2P2A3P0A4P0
    N1621A1P0A2P0A3P0A4P0 N1852A1P0A2P0A3P0A4P0
    N1622A1P50A2P50A3P0A4P0 N1853A1P0A2P0A3P0A4P0
    N1623A1P0A2P0A3P0A4P0 N1880P0
    N1624A1P50A2P50A3P0A4P0 N1881P0
    N1625A1P0A2P0A3P0A4P0 N1882P0
    N1626A1P100A2P100A3P0A4P0 N1890A1P0A2P0A3P0A4P0
    N1627A1P250A2P250A3P0A4P0 N2000P00001111*
    N1628A1P0A2P0A3P0A4P0 N2001P00000000*
    N1629A1P0A2P0A3P0A4P0 N2002P00000000*
    N1630P500 N2003P00000000*
    N1631P30* N2010P16*
    N1641A1P0A2P0A3P0A4P0 N2011P32*
    N1642A1P0A2P0A3P0A4P0 N2012P0
    N1800P00000111* N2013P0
    N1802A1P00000001A2P00000001A3P00000000A4P00000000 N2014P100
    N1803A1P00000000A2P00000000A3P00000000A4P00000000 N2015P0
    N1810P00101100* N2016P20000
    N1815A1P00000000A2P00000000A3P00000000A4P00000000 N2020A1P0A2P0A3P0A4P0
    N1816A1P01111001A2P01010101A3P00000000A4P00000000 N2021A1P0A2P0A3P0A4P0
    N1820A1P4A2P2A3P0A4P0 N2030P3
    N1825A1P3000A2P3000A3P0A4P0 N2031P4
    N1826A1P717A2P1200A3P0A4P0* N2032P4
    N2033P0 N2326P0 N2367P0 N2422P0
    N2034P0 N2327P0 N2368P0 N2423P0
    N2035P0 N2328P0 N2371P0 N2424P0
    N2036P0 N2331P0 N2372P0 N2425P0
    N2037P0 N2332P0 N2373P0 N2426P0
    N2049P-1* N2333P0 N2374P0 N2427P0
    N2051P0 N2334P0 N2375P0 N2428P0
    N2052P0 N2335P0 N2376P0 N2481P0
    N2200P01000100* N2336P0 N2377P0 N2482P0
    N2201P00000000* N2337P0 N2378P0 N2483P0
    N2202P00000100* N2338P0 N2381P0 N2484P0
    N2203P00000110* N2341P0 N2382P0 N2501P0
    N2204P00000000* N2342P0 N2383P0 N2502P0
    N2205P00000000* N2343P0 N2384P0 N2900P0
    N2221P0 N2344P0 N2385P0 N5000P00000000*
    N2222P0 N2345P0 N2386P0 N5001P1
    N2223P0 N2346P0 N2387P0 N5002P0
    N2224P0 N2347P0 N2388P0 N5003P0
    N2241P0 N2348P0 N2400P00000000* N5011P1
    N2242P0 N2351P0 N2401P00010010* N5013P0
    N2311P0 N2352P0 N2402P00000110* N5110P2
    N2312P0 N2353P0 N2403P00000000* N5111P1
    N2313P0 N2354P0 N2404P00000000* N5112P6
    N2314P0 N2355P0 N2410P10* N5120P0
    N2315P0 N2356P0 N2411P0 N5121P0
    N2316P0 N2357P0 N2412P0 N5122P0
    N2317P0 N2358P0 N2413P0 N5130P0
    N2318P0 N2361P0 N2414P0 N5131P0
    N2321P0 N2362P0 N2415P0 N5132P0
    N2322P0 N2363P0 N2416P0 N5140P0
    N2323P0 N2364P0 N2417P0 N5141P0
    N2324P0 N2365P0 N2418P0 N5142P0
    N2325P0 N2366P0 N2421P0 N5150P0
    N5151P0 N5603P00000000* N5644P0
    N5152P0 N5604P00000000* N5645P0
    N5160P0 N5605P00000000* N5646P0
    N5161P0 N5610P0 N5647P0
    N5162P0 N5611P2 N5648P0
    N5170P0 N5612P0 N5680P0
    N5171P0 N5613P6 N5681P0
    N5172P0 N5614P804 N5682P0
    N5180P0 N5615P0 N5683P0
    N5181P0 N5616P0 N5691P0
    N5182P0 N5617P0 N5692P0
    N5190P0 N5618P0 N5693P0
    N5191P0 N5619P0 N5694P0
    N5192P0 N5620P0 N5695P0
    N5200P10000000* N5621P0 N5696P0
    N5210A1P00000000A2P00000000A3P00000000A4P00000000 N5622P0 N5697P0
    N5220A1P99999999A2P99999999A3P0A4P0 N5623P0 N5698P0
    N5221A1P-99999999A2P-99999999A3P0A4P0 N5624P0 N5701P0
    N5222A1P0A2P0A3P0A4P0 N5625P0 N5702P0
    N5223A1P0A2P0A3P0A4P0 N5626P0 N5703P0
    N5224A1P0A2P0A3P0A4P0 N5627P0 N5704P0
    N5225A1P0A2P0A3P0A4P0 N5628P0 N5705P0
    N5226A1P0A2P0A3P0A4P0 N5631P0 N5706P0
    N5227A1P0A2P0A3P0A4P0 N5632P0 N5707P0
    N5420A1P0A2P0A3P0A4P0 N5633P0 N5708P0
    N5421A1P0A2P0A3P0A4P0 N5634P0 N5721P0
    N5422A1P0A2P0A3P0A4P0 N5635P0 N5722P0
    N5423A1P0A2P0A3P0A4P0 N5636P0 N5723P0
    N5424A1P0A2P0A3P0A4P0 N5637P0 N5724P0
    N5425A1P0A2P0A3P0A4P0 N5640P0 N5725P0
    N5600P00000000* N5641P20* N5726P0
    N5601P01000000* N5642P70* N5727P0
    N5602P11101000* N5643P0 N5728P0
    N6000P00000000* N6292P0 N7075P0 N7400P00000000*
    N6001P00100000* N6420A1P0A2P0A3P0A4P0 N7076P0 N7401P00000000*
    N6002P00000000* N7000P00000000* N7077P0 N7440P0
    N6010P0 N7001P00000000* N7078P0 N7441P0
    N6012P0 N7002P00000000* N7079P0 N7442P0
    N6013P0 N7010P00000000* N7080P0 N7600P00000000*
    N6014P0 N7011P00000000* N7081P0 N7601P00000000*
    N6015P0 N7012P00000000* N7082P0 N7602P00000000*
    N6016P0 N7013P00000000* N7083P0 N7603P00000000*
    N6017P0 N7014P00000000* N7084P0 N7604P00000000*
    N6018P0 N7015P00000000* N7085P0 N7605P00000000*
    N6200P00000000* N7016P00000000* N7086P0 N7606P00000000*
    N6201P00000000* N7017P00000000* N7087P0 N7607P00000000*
    N6202P00000000* N7031P0 N7088P0 N7621P0
    N6210P0 N7032P0 N7089P0 N7622P0
    N6211P0 N7033P0 N7110A1P2A2P1A3P0A4P0 N7623P0
    N6212P20* N7034P0 N7200P00000000* N7624P0
    N6213P45* N7041P0 N7201P00000000* N7625P0
    N6214P0 N7042P0 N7202P00000000* N7626P0
    N6215P500 N7050P0 N7211P0 N7627P0
    N6216P3000* N7051P0 N7212P0 N7628P0
    N6217P500 N7052P0 N7213P0 N7631P0
    N6218P10* N7053P0 N7214P0 N7632P0
    N6219P10* N7054P0 N7300P00000000* N7633P0
    N6220P0 N7055P0 N7311P0 N7634P0
    N6240A1P0A2P0A3P0A4P0 N7056P0 N7312P0 N7635P0
    N6261P0 N7057P0 N7313P0 N7636P0
    N6262P0 N7058P0 N7321P0 N7637P0
    N6263P0 N7059P0 N7322P0 N7638P0
    N6264P0 N7071P0 N7323P0 N7651P0
    N6281P0 N7072P0 N7331P0 N7652P0
    N6282P0 N7073P0 N7332P0 N7653P0
    N6291P0 N7074P0 N7333P0 N7654P0
    N7655P0 N9108P10101001* DATA Lost
    N7656P0 N9109P00001000*
    N7657P0 N9110P00000000* Data table CONTROl* DATA*
    N7658P0 N9111P00000000*
    N7681P0 N9112P00000000* D0000
    N7682P0 N9113P00000001* D0002
    N7683P0 N9114P00000000* D0018
    N7684P0 N9115P00010000* D0026
    N7701A1P0A2P0A3P0A4P0 N9116P00000000* D0034
    N7702A1P0A2P0A3P0A4P0 N9117P00000000* D0042
    N7703A1P0A2P0A3P0A4P0 N9118P00000000* D0050
    N7704A1P0A2P0A3P0A4P0 N9119P00000000* D0058
    N7721A1P0A2P0A3P0A4P0 N9120P00000000* D0066
    N7722A1P0A2P0A3P0A4P0 N9121P00000000* D0074
    N7723A1P0A2P0A3P0A4P0 N9122P00000000*
    N7724A1P0A2P0A3P0A4P0 N9123P00000000* PC Counter
    N7741A1P0A2P0A3P0A4P0 N9124P00000000*
    N7742A1P0A2P0A3P0A4P0 N9125P00000000* PC keep relay
    N7743A1P0A2P0A3P0A4P0 N9126P00000000*
    N7744A1P0A2P0A3P0A4P0 N9127P00000000* E95 C-RAM PARITY ERROR
    N8000P00000000* N9128P00000000* (HIGH) :80000
    N8010P00000000* N9129P00000000*
    N9000P2 N9130P00000000*
    N9001P2 N9131P00000000*
    N9002P16* %* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * = Best Regards
    N9100P00000000*
    N9101P00000000* Sarath
    N9102P00100010*
    N9103P00000000*
    N9104P00000100*
    N9105P00000100*
    Aug 2011
    2517
    ok. well we have a problem. or you do anyway
    This highlights that those parameters are totally different to a standard Fanuc 10T (which I have access to)
    and more importantly almost all of your parameter values are ZERO.
    My parameters in the range I mentioned above are.....
    N05101 P 00000001
    N05102 P 11000110
    N05103 P 00000000
    N05104 P 00000000
    N05110 P 0
    N05111 P 0
    N05112 P 0
    N05113 P 0
    N05114 P 100
    N05121 P 0
    N05130 P 0
    N05131 P 0
    N05132 P 1000
    N05133 P 250
    N05134 P 0
    N05135 P 0
    N05136 P 0
    N05137 P 0
    N05139 P 250
    N05140 P 50
    N05141 P 25
    N05142 P 2
    N05143 P 60
    N05200 P 00000000
    These are nothing like what you have listed and you don't have any remotely similar numbers.
    Plus there is a heap more parameters doing other things and they all make the machine work properly.
    Since you lost all of them you will never make it work properly without a full backup of all of the parameters from a working machine like yours. That's the ONLY way you will get it working.
    Mar 2011
    N05101 P 00000001
    N05102 P 11000110
    N05103 P 00000000
    N05104 P 00000000
    N05110 P 0
    N05111 P 0
    N05112 P 0
    N05113 P 0
    N05114 P 100
    N05121 P 0
    N05130 P 0
    N05131 P 0
    N05132 P 1000
    N05133 P 250
    N05134 P 0
    N05135 P 0
    N05136 P 0
    N05137 P 0
    N05139 P 250
    N05140 P 50
    N05141 P 25
    N05142 P 2
    N05143 P 60
    N05200 P 00000000
    Thanks, do your screen wive is same to the mine? If it is can you copy what you find on the page of Data Table CONTROL DATA from:
    D0000
    D0002
    D0018
    D0026
    D0034
    D0042
    D0050
    D0058
    D0066
    D0074
    BEST REGARDS:cheers:
    Aug 2011
    2517
    I said I have access to 10T, but not Hitachi machine. It's Mori Seiki TL40. standard Fanuc parameters are totally different.
    Hopefully you can get a full parameter backup from Capt Crunch?
    Mar 2011
    OK.Thanks then I'll try Capt Crunch.:cheers:
Page 1 of 2 12
  1. Lost all Hitachi Seiki TF 20
    By VIDE in forum Fanuc
    Last Post: 02-12-2014, 05:51 PM
  2. hitachi seiki HT20 Data probleme
    By emind in forum Community Club House
    Last Post: 02-16-2013, 06:03 PM
  3. Replies: 0
    Last Post: 04-20-2012, 06:38 PM
  4. lost Data hitachi seiki HT 20
    By emind in forum Fanuc
    Last Post: 10-19-2011, 08:21 AM
  5. Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 05-05-2011, 04:12 AM
