0 active members*
4,653 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > 800W Spindle & 1.5KW VFD **US version??**
Results 1 to 5 of 5
    Mar 2011
    9
    Many of the small Chinese CNC Routers, typically the 6040s, spec a 110v version for the US market. These include a 800W Spindle & 1.5KW VFD.
    But, I have not been able to get an answer whether the spindle and VFD still require 220v or whether the VFD does an up conversion 110v one phase -> 220v three phase.
    Does anyone know what is typically provided. Anyone have a US version of a 6040?
    Edit: Numerous views, but no answer. I do realize that 220v is preferred, but does anyone have any experience with a 110v setup?
    Thanks...
    Oct 2006
    12
    I am also trying to find out if they really have a 110V version of their spindle motors, as mentionned in their spec sheet. Example here:
    HIGH SPEED 0.8KW AIR COOL MILLING AND DRINDING INVERTER SPINDLE MOTOR v | eBay
    If you ask them, you will get a reply like this:
    dear friend
    this item both canuse with 110v and 220v
    But as is known, if you run a 220V motor on only 110V, you will get only 1/4 the original power out of the motor.
    I asked the same question to another seller, and he replied :
    dear friend
    you can buy this one
    PROFESSIONAL 1.5KW 7A 220-250V 2HP VARIABLE FREQUENCY DRIVE INVERTER VFD b | eBay
    So instead of replying about the availability of a 110V motor, he tells me that I can buy a VFD...
    Does he mean that this particular VFD could be run on 110V and drive a 220V motor??? That drive is not specified for 110V in the specs...
    I would dearly like to know if anyone has ever managed to get one of those 110V motors.
    I planned to use an Emerson Commander VFD, that is made to run on 110V.
    Alternatively, on one of those 220V chinese VFDs, if I was to input the same phase of 110V on two terminals, and the neutral on the third terminal, would that work?
    Altair
    Feb 2012
    16
    I ordered a CNC 6040 a few weeks ago from "industry-village" on eBay. The seller goes by a number of names on eBay (location is always San Leandro, CA), but in the end the seller is apparently [email protected].
    In any case, I waited a few days and upon hearing nothing about my order I sent a message asking when I could expect delivery. After several messages back and forth (always with a reply starting with "dear friend") I finally figured out that they were out of stock in the US and the shipment coming to their US warehouse from China was delayed. After only a slight complaint from me, they offered to air freight the machine from China via DHL at no additional cost. Six days later I had my machine. I was stunned at the great customer service!
    Anyway, to my surprise the machine I received was a 110V model - controller and VFD are both 110V.
    Communicating with them is tough as their English is pretty rough (though infinitely better than my Chinese), but the service I ended up receiving was top notch.
    I suggest being patient and polite, and keep asking them in different ways for a 110V model. I know they can get them!
    Oct 2006
    12
    Thanks Qubert !
    I'm glad to know that they can really obtain the 110V models.
    Have you checked on your spindle motor to see if it is also marked 110V ?
    I wil contact them again with my request, in the hope of getting a better answer. Funny how there are so many company names, and they are all mysteriously located in San Leandro...
    Altair
    Re: 800W Spindle & 1.5KW VFD **US version??**
    Greetings,
    I recently acquired an:
    USB 4 AXIS 1.5KW CNC 6040Z Router Engraver Wood Drill/Milling Machine+Controller, at 110v
    Details:
    USB control box SXCNC 6040Z
    PSU-s-250w-24v 10A (AC input 115 VAC, 5.5 A / input 230 VAC, 3.5 A)
    Nema 23- anchor motor 57HD5401 14S 1.8 ° 3A
    Spindle motor : 0.8KW, 110v, 4A, Hz, 24000 RPM, water cooled.
    VFD -NOWFOREVER 1.5 KW, (AC input 110v 50/60 Hz, output 110 VAC; 15.0 A)
    The spindle motor is labeled:
    GDZ-65-800A - O 65x158
    110 800w 4A
    400hz 24000 rpm
  1. 800w Spindle Slipping
    By magudaman in forum Chinese Machines
    Last Post: 04-01-2014, 04:18 AM
  2. Replies: 0
    Last Post: 08-03-2013, 07:01 PM
  3. Kress 800w router
    By Bernard in forum CNC Tooling
    Last Post: 09-20-2012, 08:36 PM
  4. different version spindle driver board
    By david_geng in forum Syil Products
    Last Post: 09-07-2007, 12:08 AM
