585,992 active members*
5,533 visitors online*
    Oct 2005
    169
    Question Acu-rite Glass scale testing
    Hi All,
    I have a couple old acu-rite glass scales I am trying to test because I am thinking of using them on a project I am working on. I tried putting +5v to pin C and pin d to ground. Then I hooked my oscilloscope probe to pin A and slid the scale hoping to see a square waveform. Both scales I have showed nothing. Is there something else I need to do in order to test channel A or B?
    Thanks!
    24221
    Normally there is no problem reading the output, but the head and scale is usually mounted with the right gap etc. If the scales were supposed to be working, this may be the reason.
    Al.
    Albert E.
    Oct 2005
    169
    Hi Al,
    I'm not sure if they are supposed to be working or not. They were in a box in the back of my shop for a long time and I am not sure where they came from. I did not have them mounted and gapped, but I expected to see at least a blip on the screen when I moved the reader?
    Maybe I will mount them and try again.
    Thanks!
    Oct 2005
    169
    Got it - I found a bad wire running to the encoder head. It shows a nice square wave now on both channels moving it by hand even while unmounted. I think I will try to use this on the ID grinder project.
    Thanks!!!!
  1. Acu rite Millmate scale needed.
    By fujiman in forum Want To Buy...Need help!
    Last Post: 03-09-2011, 06:31 PM
  2. Acu-rite Glass Scale Position
    By pofo in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-02-2011, 03:58 PM
  3. Using an Acu-Rite scale on a Grizzly DRO???
    By ranchak in forum CNC Machine Related Electronics
    Last Post: 09-15-2008, 12:19 AM
  4. DIY Adaptor for Acu-Rite glass scales?..
    By hotponyshoes in forum Uncategorised MetalWorking Machines
    Last Post: 04-30-2008, 01:32 PM
