585,997 active members*
5,055 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > Desktop or a bit larger CNC with min 6" Z
    Sep 2005
    66
    Looking for a desktop or maybe a little larger 3 axis CNC but I need a minimum of 6" in Z for the projects I need it for.
    contact me if you have any leads or can help
    Pricing is dependent on quality.
    Apr 2004
    5737
    The Taig desktop mills
    have 6" travel in Z. They are small but "overbuilt" machines made in Arizona, and reperesent a great value for their quality level. If you need more clearance, you can raise the whole Z axis box ways assembly up on the column for even more room in the vertical direction.
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Mar 2011
    9
    XZero machines have 6" Z
    Check out XZero. They have a forum here.
    Dec 2007
    379
    Your looking for a 3 axis CNC what? Router or mill? If you need a router, are your looking for 6 inches of usable Z travel or 6 inches of gantry clearance?
    Sep 2005
    66
    Need 6" of workpiece clearance. Cutting mostly aluminum. Need to be able to do some squaring of blocks also. Want 3D capability.
  1. EXLAS "smart" Desktop laser-COMING SOON
    By EXLASer in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-26-2011, 02:19 PM
  2. Replies: 11
    Last Post: 05-18-2010, 03:01 PM
  3. First Machine HELP...24"x36"x4" or Larger Setup w/ Gecko for under $3000
    By buschhoff in forum Want To Buy...Need help!
    Last Post: 03-21-2010, 12:37 AM
  4. Replies: 0
    Last Post: 11-23-2009, 11:45 PM
  5. 24"X, 18"Y, 3"Z Steel Frame Desktop Machine
    By TLHarrell in forum DIY CNC Router Table Machines
    Last Post: 06-16-2009, 06:33 AM
