585,749 active members*
3,830 visitors online*
    Jun 2005
    180
    Image Creation
    I need to turn x, y & z coordinates to an image. The x & y are equally spaced, and I can convert the z into color number. What is the easiest format to use?
    Jul 2005
    66
    I've always found the TGA file format to be the easiest to write out to disk. Bitmaps (BMP) have a lot more header information and while they are not insanely difficult, TGA's only have one big header and then the data comes right afterward, so writing them out is simple.
    -nt20
    Aug 2013
    i perfer bitmap as well when we are creating an images by using x y & z coordinates. it is simple to do with TGA, you can find a lot of sample codes on the web.
    Mar 2014
    Quote Originally Posted by nationmore View Post
    i agree with you. cam you show us some tutorial or sample codes you found on the internet. thank you in advance.
