I am working on a design that consists of the following:
1/4 steel inch shaft sliding in 1/4 inch hole in aluminum.
The shaft has external retaining rings to limit motion from end to end.
It will have to be turned to cut grooves for the rings.
The hole is 0.750in long.
There are two of these shafts running parallel to each other and about 1.6 inches apart. Both guide holes are in the same block of aluminum.
I want to be smart in material and size selection in order to avoid this thing being more complicated (and expensive) than it needs to be.
First would be material selection for the rod. It will have to be cut and grooved, which means that it can't be hardened steel shafting. I don't want to turn something to 0.250, I want to stick with stock sizes. What are the range of diameters one might get if I specify nominal 1/4 steel rod?
Now, the holes need to allow for a smooth sliding action. Motion is slow. No need for bearings. This is basically a clamping mechanism. I want to make it so that hole manufacturing isn't anything special. If the rod is undersized a little maybe I can specify a 0.250 drilled hole. My guess is that it is more reasonable to go with an F drill and get a 0.257 hole. This might allow for tolerances in both the rod diameter and the center-to-center distances between the holes.
What are best practices when dealing with something this simple: A 1/4 rod sliding in a 1/4 hole. Simple, but not so if you look at the details of making the thing.
Thanks!
-Martin
