Originally Posted by
Haastec2
.....Using the Mcodes the machine won't be able to detect overcurrent conditions if the auguer binds up,...
This is true but you would simply have an overcurrent protection in the supply running to the auger motor. And you would never run a large inductive load directly through the onboard M code relays you would have them operate a low voltage solenoid relay external to the machine as I have described in several threads/posts about using M codes to run external equipment.
The big question is how much does and IO board with the chip auger controls on it cost. How readily available it it in the OP's location. The components to build something using the M code relays are readily available and the cost would probably be not more than a couple of hundred dollars.
