So, I upgraded to version 24 some time ago and for the most part I'm happy with the upgrade. The other day I opened a part that I had designed and created on my mill using V23 and upgraded to V24 and simply moved the part to zero from a new point and some other small changes. I regenerated the toolpath and interestingly the tool path on the Z Level Finish, isn't the same? I checked that I was using my post processor from V23 and I am (since I had made changes over time to it).
Attached is a screen shot of the differences along with the actual V24 drawing. I've double checked everything, even recreated the surfaces and tried to regenerate and the .031 square endmill won't make the same cuts around the lettering.
Any help will be greatly appreciated.
