585,992 active members*
5,225 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > best insert grade and brand or 304 ss
Results 1 to 8 of 8
    Aug 2011
    77
    looking for your opinon on best turning grade for ss
    thanks
    Jan 2007
    1389
    sandvik or iscar
    Nov 2007
    479
    check into kennametal beyond or seco duratomic grades.
    Jul 2010
    492
    i love the 1125 grade of sandvik personally, ran dry.
    Apr 2006
    3206
    I really like Sandvik's grades for 304...but it depends on whether you're turning or milling! And depends on roughing, finishing...etc.
    Some of their grades are insert specific.
    As Shane mentions...they do like dry better, and you have to have the horsepower and rigidity to get your money's worth out of 'em. They LIKE to be worked.
    (had a Sandvik rep tell me he liked the 4 sided turning inserts better...So I don't fully trust everything they say. With a WNMG I get 2 extra edges for essentially the same price.)
    Jul 2010
    492
    Quote Originally Posted by fizzissist View Post
    i agree, i use the wnmg 432's, 1125 grade, and hog thru stuff in the lathe, round & hex & square bar it dont matter.
    Aug 2011
    77
    horse power and rigidity not a problem
    turning in a lathe
    roughing and finishing
    and you run it dry?
    I am running it in a bar feeder
    if you run dry how do you hold size with all the heat?
    Jul 2010
    492
    when i run my wnmg 432 rougher, i run it at g96 s450 with .08 to .1 depth of cut, feed of .012 per rev. all the heat goes with the chips buddy i leave .01 to .015 for a finish pass and use a finishing insert for final size. sometimes i run coolant, sometimes i dont, but i only run the finish at .005 per rev for feed, but g96 s650 for rpm my rougher lasts longer than my finisher 99.99% of the time, usually only change corners on the rougher inserts about 2 times a week.
  1. Material 514 Grade B/Q
    By damage inc in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 03-22-2011, 06:41 PM
  2. Insert grade look-up
    By Sam HAmen in forum MetalWork Discussion
    Last Post: 03-26-2010, 05:29 PM
  3. What is Grade Engrave?
    By SkipW in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-23-2007, 10:10 PM
  4. Looking at Mid Grade Routers
    By Trouble Creek in forum Commercial CNC Wood Routers
    Last Post: 11-02-2006, 06:42 AM
