585,973 active members*
4,130 visitors online*
    Oct 2008
    23
    Limit and Home Switch in Mach 3
    Does anyone know if you can use only 3 switches (XYZ) for both limit and home switches in mach 3?
    Yes.
    But, if you want to use them for both + and - limits, you'll probably need to mount the switch to the moving parts so that it can work at both ends of travel.
    Oct 2008
    23
    Yes.
    Or have 2 pins on each end of the travel. Same thing.
  1. Is it possible to use the home switch as the limit switch as well?
    By Darc in forum Mach Software (ArtSoft software)
    Last Post: 11-02-2012, 06:25 PM
  2. limit switch- home switch
    By normd in forum CamSoft Products
    Last Post: 05-17-2008, 12:56 AM
  3. limit switch and home switch setup
    By Runner4404spd in forum CNC Machine Related Electronics
    Last Post: 12-15-2005, 02:58 PM
  4. Limit Switch / Home Switch in Software
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 12:58 AM
