Starting new business similar to Metal Supermarket and a Waterjet Cutter as value added. Metal Supermarket is expensive, but I do not see any competitors that are a franchise. Any suggestions ? Looking for what you need for value added example would you find metal shearing or pipe bending to be useful or does your local machine shop do you fine already. A Omax 4x8ft waterjet cutter is already in the initial plan, but is there anything else that you would find useful in minor machining or cutting for example ?
