Originally Posted by
iaknown
Thanks for the quick reply.
1) So there are no G-codes that can override the feed?
2) OK makes sense however: "then use an IF/GOTO function to return the program to the top" Sorry, I never learned how to do macros, can you expound? And how should it look in my code?
M02 and M30 are the same correct? I've always used M30
I can actually manage changing the post pretty well. I've already done it for a few machines/makes. Takes me forever playing around with it but I eventually get what I want.
1) Yes there is a code for changing the feed, it's F-just not the rapid. (Sorry, I had to.) It is annoying at first but soon it will be second nature and no big deal. Use canned cycles, watch the first pass, turn off single block, and let it run
2)Why not just shift zero by so much each part? There is a macro, something like [IF] VZSHFT. Budgie or one of the other guys will correct me. I never use it because it is just way too easy to just move the part zero.
Robert
The beaten path, is exclusively for beaten men.
