585,748 active members*
3,676 visitors online*
Results 1 to 10 of 10
    May 2011
    212
    Rails placement for X-axis
    I recently started my build and I'm about to start drilling holes for the rails on the base for the x-axis.
    Would I want to place the rail high up, or lower down on the aluminium bar with regards to sideway forces on the gantry?
    See the attached pic. (Text is in Norwegian, but you'll get the idea)
    Aug 2008
    409
    higher is better if it means your gantry uprights will be shorter.
    May 2011
    212
    Quote Originally Posted by Phife View Post
    The rails is not going to affect the height of the uprights. There is going to be a flat bar running underneath the base as a part of the gantry.
    Aug 2008
    409
    Still, the upright part above the rail you want to be as short as possible, so the higher up design is better as it leave less distance from rail to gantry top.
    May 2011
    212
    All right, thanks allot Phife.. farthest up it is. Have a good one:cheers:
    Oct 2011
    henrikm,
    I am a little bit ahead in my design, but we seem to be working on the same details. I am of the opinion that if you drive from the bottom plate with a single screw, you will get better triangulation with mounting the rails higher. If, on the other hand, you drive from the sides with a twin screw, placing the screw axis plane above the plane of the rails seems to be the best way to deal with gantry inertia.
    Question for you, since you are also in Europe, where are you sourcing your parts and materials for this build?
    May 2011
    212
    Quote Originally Posted by LBSamurai View Post
    I am of the opinion that if you drive from the bottom plate with a single screw, you will get better triangulation with mounting the rails higher. (...)
    I have a single screw on my bottom plate, so high it is then
    The aluminum stock I got through work from a Norwegian supplier. Think I payed something in the area of 5 euros/6 usd per kg.
    The screws, rails, blocks and so forth is from linearmotionbearings2008 on ebay. The motors (nema23) and Gecko540 is from cncrouterparts.com.
    I still need to get a hold of a spindle and a vfd. Most likely a Hitachi X200 vfd and a chinese watercooled 2,2 kW spindle. Not sure where to buy yet.
    Yesterday I got most of the Z-axis sorted out. Going to get started on the ball nut mounts today. Will post some new pics later.
    Oct 2011
    Quote Originally Posted by henrikm View Post
    Wow, it looks like we're on the same sheet of music. I'm going with the same vendors for linear motion components and electronics, but I am still looking for the best deal on extrusions and Al plate. Looks like Valuframe UK is going to be my source for extrusion, since my design is based around 60/120mm. I think the Al plate will be the part to ruin my budget here. I need some specific cuts and precision drilling, since my manual mill is in storage for now. I'll probably try to source that through the RFQ channel on this forum, as I imagine a job shop in Germany would be very costly. Thanks for the response.
    May 2011
    212
    Keep me updated on your build. Would be fun to compare designs. I'm planning to have most of the machine ready before new years, but don't think I can afford a spindle/vfd for a couple of months. Do you have a build log?
    Oct 2011
    I have most of the design work completed in SolidWorks. I didn't want to start a thread without something to show on the first post, or else it is not a build log . I'll get something up soon, I want to show my design before I begin ordering parts. Are you working on a build log yourself?
  1. SSR 15 THK rails for Z axis?
    By lasterixsuedois in forum DIY CNC Router Table Machines
    Last Post: 12-08-2009, 12:19 AM
  2. Linear Rails for the Z Axis
    By Bird_E in forum Charter Oak Automation Support Forum
    Last Post: 08-31-2007, 07:45 PM
  3. Z-Axis Ball Nut Placement - I Screwed Up Instead of Down!!
    By bill south in forum Benchtop Machines
    Last Post: 04-01-2007, 07:47 PM
  4. Add a second set of rails to X axis..need advice.
    By bgolash in forum DIY CNC Router Table Machines
    Last Post: 06-01-2005, 01:11 AM
  5. Y-axis rails
    By 2muchstuff in forum Mechanical Calculations/Engineering Design
    Last Post: 04-15-2005, 04:01 AM
