Hello all,
In the process of decide some basic structure issues, i have a couple of questions i really like you to comment / give your opinions:
1- In the gantry itself, the rails position give a better support to the Z axis if they are both in the same plane (A) ("vertical position" ?), or in separate planes (B) (vertical + horizontal). I had some quick renders to explain what i am saying.
I guess it's easier to build in the same plane regarding the aligment right? Just wondering if option (B) give more support...
2- In the Z axis, i have seen using this two options for the rails: The "traditional" system with fixed rails and the trucks move along with the "Z plate" (option A), and the oposite where the trucks are fixed, and the rails are the moving part. I think the 1st option has the advantage of having a lighter Z plate (even considering the weight of the trucks), also the rails don't go so near the dust. In the other hand, in option (B), i wonder if the rails itself give a better stiffness to the Z plate, acting as a structure beam... Again renders of it.
Please give your opinions, that will help a lot deciding what design to choose. Even if you have other theorys, their welcome too.
Thank you for your help,
Rui
