585,938 active members*
3,682 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Post Processors for MC > Modify post to post G02 and G03 modal
    Nov 2005
    244
    How would like my post to list a G02 and a G03 with each line? This is the code now.
    N170 G1 Z2.36 F200.
    N180 G41 D4 X2.178 Y-.7128 F14.06 (CUTTER COMP)
    N190 G3 X1.9494 Y-.8075 I-.0669 J-.1616
    N200 G2 X1.7493 Y-1.1799 I-1.9494 J.8075
    N210 X1.5508 Y-1.2088 I-.1126 J.0767
    N220 X1.2088 Y-1.5508 I-1.5508 J1.2088
    N230 X1.1799 Y-1.7493 I-.1056 J-.0859
    N240 X.4026 Y-2.0712 I-1.1799 J1.7493
    N250 X.2418 Y-1.9513 I-.0257 J.1334
    N260 X-.2418 I-.2418 J1.9513
    N270 X-.4026 Y-2.0712 I-.1351 J.0135
    This is where I think it needs to be changed
    pcirout1 #Output to NC of circular interpolation
    pcan1, pbld, pn, `sgfeed, sgplane, sgcode, sgabsinc, pccdia,
    pxout, pyout, pzout, paout, pcout, parc, feed, strcantext, scoolant, pcccomment, pe
    Thank You
    Nov 2011
    19
    Do you know where in mastercam post, to eliminate these N numbers at the start of every single block? It would be good to turn this function off.
    Dec 2008
    3109
    Quote Originally Posted by camtd View Post
    You are in the correct area, there may be another pcirout ??
    use a * in front of the string the force that item into the NC file
    -----find sgcode, change to *sgcode
    Quote Originally Posted by mori.seiki.user View Post
    -It's not in the post for the X series
    --> Open the Machine Definition File,
    --> then open the Control file for that machine,
    --> go to the NC File tab & uncheck the "Use sequence numbers",
    --> accept the changes while backing out of the files
    This is the same area that you go to to alter the actual numbering pattern defaults. ie the default start at N100 and increment by 100, you may want to start at N1 & increase by 1.
    Nov 2011
    19
    You are correct with eliminating the N sequence numbers, but to get into where you're talking about, first select SETTINGS in top menu and MACHINE DEFINITION MANAGER.Then find EDIT CONTROL DEFINITION icon at top, then select NC OUTPUT at left. In this page un-select OUTPUT SEQUENCE NUMBERS box. It takes some looking without knowing each step.
  1. Modify MasterCam post
    By jeffrey001 in forum Uncategorised CAM Discussion
    Last Post: 07-03-2009, 09:28 AM
  2. How to Modify Post Processor?
    By Stampede in forum BobCad-Cam
    Last Post: 09-26-2008, 09:00 PM
  3. 31i-A5 which post to modify
    By jrobson in forum Fanuc
    Last Post: 02-27-2008, 12:34 PM
  4. how can i modify the post?
    By ahmedsamy_81 in forum Post Processors for MC
    Last Post: 07-16-2006, 08:25 PM
  5. Post Processor (ISO G-Code - Non Modal)
    By cncadmin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-29-2005, 02:32 PM
