585,883 active members*
4,639 visitors online*
Results 1 to 15 of 15
    Feb 2006
    55
    4th Axis Direction Question
    Can you folks with a Tormach 4th axis tell me which way your axis moves when you do a positive axis move. This would be as viewed from the end of table which the chuck faces. CCW or CW?
    Jeff E.
    Nov 2011
    My brand new rotary table moves CCW looking at the chuck with a positive A move. Not sure if it's right or wrong, but I think it's right since it matches the engraved marks on the side. Hope that helps.
    Feb 2006
    55
    Thanks Dan,
    I believe that yours is correct. Mine (2 years old) was set up the opposite way because the marks on the table itself were positive CW an negative marks were CCW. Guess if it was mounted on the right side the marks would be correct :-) Anyway I recently changed it to operate like yours.
    Thanks for you response
    Jeff E.
    May 2006
    1469
    I know you asked about Tormach but your heading said "4th axis direction question" which may lead other readers here. So this is a general response.
    Descriptions for A axis direction are often confusing.
    I find the Right Hand Rule to be the best way to describe it. Makes no difference which way your headstock is mounted or where you are looking from.
    Take your right hand, make a fist, point your thumb in the positive
    direction of an axis, the direction of your fingers gives you the
    positive direction of rotation around that axis.
    Greg
    Mar 2008
    256
    For the record: Is that the direction the axis rotates, or does it represent the tooltip motion relative to the axis as it rotates?
    Feb 2006
    55
    Quote Originally Posted by flick View Post
    Flick,
    It is the way the axis rotates.
    Jeff E.
    Mar 2008
    256
    I was actually hoping for a reply from Greolt. He seems to speak with some authority, and notes that many descriptions of rotational axis motion are confusing, and then provides an incomplete description himself.
    So we're supposed to think of linear axis motion in terms of tool movement, regardless of whether it's actually the tool or the work moving, but we're to think of rotational motion in terms of part movement. Suppose this still applies if your rotational axis is actually implemented as head motion?
    I've arbitrarily declared my rotational axis motion to be positive and negative in terms of relative tool motion in the same directions that Y is positive and negative as seen from the operators normal point of view, looking down on the work at the near side of the rotational axis. This happens to correspond to Greolts description of the right hand rule, if he was indeed referring to work/axis motion, as opposed to relative tool motion.
    Unfortunately, this means that the Mach simulation is backwards, as is the engraving on the rotary head. I'm planning to engrave another set of numbers next to the original, and fill them with black paint, while filling the original with red, but I don't know what to do about the simulation...
    Feb 2006
    55
    Sorry for the reply - I now feel so insignificant
    Jeff E.
    Feb 2006
    7063
    I think Greolt's answer was quite clear. If your 4th axis is aligned to the X axis, then point your thumb in the direction of X+, which will be to the right when facing the front of the machine. Your fingers will then be curling up and to the front, indicating the 4th axis positive rotation direction will be CW when viewed from the left end of the table, or CCW when viewed from the right end of the table.
    Regards,
    Ray L.
    Mar 2008
    256
    Uh Srsly? :drowning: I didn't mean to offend, just trying to get greolt's attention so he might respond as well.
    Here, maybe a dancing banana will cheer you up...
    :banana:
    friends?
    Quote Originally Posted by Jeff E. View Post
    Jeff E.
    Mar 2008
    256
    Ok. One more try. Do you suppose that "axis motion" as it relates to rotary axes actually refer to the motion of the workpiece, or the tool relative to the workpiece?
    I fell into the trap of using axis and workpiece motion interchangeably in my own posts, but It's not really clear that they are the same. In fact, they might be interpreted as being quite the opposite.
    Quote Originally Posted by HimyKabibble View Post
    Regards,
    Ray L.
    Feb 2006
    55
    Flick,
    The banana worked, I'm good.
    Jeff E.
    Feb 2006
    7063
    I've never seen a rotary axis described in terms of tool movement. That would only make sense if there were rotary machines where the work was stationary, and the tool orbited around it, which I've never seen. The tool/machine distinction is necessary for linear axes, as there are just as many machine which move the table around the tool, as there are that move the tool around the table, so one configuration or the other HAD to be defined as the standard frame of reference.
    Regards,
    Ray L.
    Mar 2008
    256
    [ame=http://www.youtube.com/watch?v=yHRk3_WQe2Q]4th Axis Indexing Spindle - YouTube[/ame]
    Regards,
    Ray L.
    Jan 2015
    417
    Re: 4th Axis Direction Question
    The fingers represent the cutting direction. So if you are looking at the face of the rotary table and move A+ the face of the rotary rotates CCW.
  1. Axis Direction Question
    By captianpattson in forum Benchtop Machines
    Last Post: 10-12-2012, 07:45 AM
  2. Newbie facing direction question
    By Little Skippy in forum Mastercam
    Last Post: 08-08-2012, 08:43 AM
  3. X axis works fine but Y axis direction is erratic
    By swampbud1 in forum DIY CNC Router Table Machines
    Last Post: 12-07-2010, 12:28 AM
  4. pos/neg direction question
    By oldhack in forum Mach Mill
    Last Post: 01-16-2010, 06:28 AM
  5. z axis direction question.
    By ljoe1969 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-22-2004, 02:53 AM
