do you guys know where can i download a speed and feed chart in metric for carbine endmill, carbide ball-nose, HSS. I usually cut 1030 to 1050 steel and P20 steel.
I often set carbide speeds from 3000 to 6000 rpm. with feeds from 1000 to 2500 and my depth of cut is .02 to .1 mm and use cutting oil for diposing of chips and coolant. is it right or wrong to use these settings? thanks!
