585,555 active members*
3,162 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Solid Works Ver: 2007 and Windows 7 Pro
    Nov 2007
    Question Solid Works Ver: 2007 and Windows 7 Pro
    Has anyone gotten SW-2007 to run smoothly in Windows 7 Pro? If you have please, post instructions.
    Feb 2008
    389
    install SW 2007 then right click on the short cut and click on properties then click the compatibility tab. Click on "Help me choose settings" or you can try putting a check in the check box for "Run this program in compatibility mode for:" and choose your own settings in the drop down box, probably something like "Windows XP (service pack 2)" or similar. You will probably have to click on yes in User Account Control dialog that comes up every time you start up SW.
    HTH
    May 2010
    307
    Or you can choose to disable the User Account Control.
    Instructions
  1. Does anyone have a GCC Spirit which 'WORKS' on windows Vista / USB ?
    By KPBadger in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-02-2011, 10:40 AM
  2. Solid Works 2007 Question
    By SPEEDRE in forum Solidworks
    Last Post: 03-07-2011, 01:50 AM
  3. 2007 & V21 with Windows Vista :(
    By TZ250 in forum BobCad-Cam
    Last Post: 10-13-2007, 06:06 AM
  4. Camworks 2007 on a 64bit Windows
    By Andreas0815 in forum CamWorks
    Last Post: 09-28-2007, 01:50 AM
  5. Which came first, Solid Edge or Solid Works?
    By Arnie in forum Uncategorised CAM Discussion
    Last Post: 09-15-2004, 12:25 PM
