hello newbie here, i just received a new (old) 1984 shizouka turret mill with a anilam crusader 2 control, there is a few problems im having with this unit. i have fixed most of the bugs so far myself. the z axis has a auto tool release up top it is a pancake style air cylinder which pushes down on the draw-bar.
the draw-bar has spring washers on it and the lower portion of the draw-bar has a split tapered shaft where the tool is held so it shrinks (so to speak) and lets the tool out and vis a versa. the problem .....lol when i hit the tool change button the cylinder crams the z axis down for example the z axis is holding or trying to then gives up and faults code 18 and faults the z driver board. then i have to reset the board and crusader then it will do this over and over.
im kinda new to the cnc stuff myself so im trying to understand all the terms and stuff , i would think there is something that should shut off the z axis momentarily , when the tool-changer is activated i can hear the driver board and fans lower speed and noise cause its straining, i know its not right thats obvious... im wondering how it originally worked?
there are clamps that slide under the lowest spring washer to hold it from going down ....but there seem to be a window of room that will never go away so it still loads the driver boards and faults out
there was a relay at the bottom of the cabinet which was not supposed to b there from anilam and not in the wiring diagram ,and everyone i have asked(that worked on these or for anilam) said thats not suppose to be there, it has something to do with the spindle control/tool changer control/coolant control. alot of this stuff was disconnected when i received the machine. and its still disconnected ...some wires are wirenutted together some dont go to anything
i have the wiring diagrams for this controll (anilam) also but the tool changer was a add on i beleive
problem 2 is the z axis wonders back and forth when its not in use
i beleive the problem is in the scales needs cleaning or zeroed
it was a real basketcase for sure but i hate to give up on such a nice setup
i just got the rs232 port to work cost 1.05$ to repair myself
its a 3 axis machine really stout peice of equipment id love to be making chips already!!! i can post pics or a video of what its doing.
i have alot of ... i mean a shhhhit ton of hrs trying to repair this already
im getting somewhere just not where i wanna be lol if anyone has any ideas or had this problem pleas email me or pm me slammedbike at y a hoo dot c o m
save me please!!!! lol thanks for any info
