The last shop I worked in had a large red hard cover book that listed all metals and the surface footage that should be used when machining. The format was in columns for metal type and grade, surface footage for high speed steel cutters, and surface footage for carbide cutters (with different grades I believe.)
It was split into separate sections for milling, turning, boring, drilling etc.
I believe there were two volumes to this but we only had one volume and it covered almost every metal.
Does anyone have an idea what the name of this book might be?
Thanks.
