585,604 active members*
3,272 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Industrial temperature control solution
Results 1 to 6 of 6
    Jan 2006
    2985
    I have a need for a temperature controller which will use a thermocouple as the setpoint and a different thermocouple as feedback.
    I have 2 heaters and I want the second one to follow the temperature of the first. I want to use a TC in the first one to determine the setpoint for the controller of the second one.
    I would prefer a discrete controller although PLC may be an option if necessary. I have a few vendors working on it but I'd appreciate any input regarding this type of controller, it seems none of the standard controllers have this ability.
    Matt
    24220
    One of the biggest names in temp control is Omega, I believe they have an engineering dept that you can run you your requirements past them and see if they have anything off the shelf or suggestions.
    Al.
    Albert E.
    Feb 2009
    6028
    Al.
    Agree with Al. Doing the same thing here for 10 machines. Expensive, but no messing around.
    Jan 2006
    2985
    Omega is one of the ones working on it. Their best answer so far is a $650 PLC solution and then I have to buy a comms cable and write the control algorithm in ladder logic. I was hoping for plug and play as I don't have alot of time to get this project done.
    Matt
    May 2004
    162
    TC controller
    Quote Originally Posted by keebler303 View Post
    Matt
    1. This appears to me to be an inexpensive solution.
    2. Maybe you shouldn't have taken on this project if you don't have time to give it a proper solution.(chair)
    Jan 2006
    2985
    Quote Originally Posted by p38nut View Post
    1. I was just stating the cost for general info, I don't think its expensive either.
    2. If only I had the option. Building custom test systems on (relatively)short timelines is what pays the bills. That and putting out the proverbial fires.
    I'm somewhat of a perfectionist, borderline OCD about certain things. I'm not gonna short change the quality of my work due to a tight timeline, I just have to work more hours.
    I just got off the phone with Eurotherm. For a little more than Omega, they have a discrete controller which will take a TC input as a setpoint. Only a few parameters and a little labview style function block programming and I'm in business. I am already familiar with this family of controllers so the learning curve should not be too steep.
    Thanks for all the input
    Matt
  1. CIB Industrial Control Interface
    By antsals in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-18-2011, 11:51 PM
  2. Temperature
    By rjsmith in forum CNC Swiss Screw Machines
    Last Post: 08-05-2010, 04:57 AM
  3. Head temperature
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 12-10-2006, 11:33 PM
  4. Looking for usage ideas for PLCs and other industrial control bits
    By Boilermakr in forum Community Club House
    Last Post: 02-21-2006, 03:26 PM
  5. Using temperature as a fastner
    By pminmo in forum MetalWork Discussion
    Last Post: 02-09-2005, 10:36 PM
