585,670 active members*
4,383 visitors online*
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Jul 2011
    Further considering the costs of the linear guides, they are actually only required for the z-axis. If you keep the segments seated with conical pins at the wheel with spring force and drive the segment down with a foot shaped guide, than you would require only one expensive linear guide.
  2. #22
    Jul 2011
    oops, feet need to be wider, else the segments don't fit through the z-axis rods.
  3. #23
    Mar 2011
    Re: Open source P&P revolver head
    actually i am confused in the vacuum distribution design.
    how it work actually?
    Possible to share me the detail?
Page 2 of 2 12
  1. Open Rail - open source linear bearing system
    By milatary56 in forum T-Slot CNC building
    Last Post: 06-09-2012, 02:07 PM
  2. open source 3d scanner
    By zhanx in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 11-11-2011, 01:28 PM
  3. OPEN SOURCE BLUEPRINTS?
    By denis6902 in forum Open Source CNC Machine Designs
    Last Post: 03-05-2010, 02:04 PM
  4. Open Source Cad Cam
    By kch in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-30-2007, 12:51 AM
  5. What's in work at the open source
    By pminmo in forum Open Source Controller Boards
    Last Post: 02-13-2005, 08:55 PM
