585,981 active members*
4,470 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Getting g-code from the computer to the cnc
Results 1 to 3 of 3
    Jul 2005
    25
    Red face Getting g-code from the computer to the cnc
    We are running a vmc6030 and experiencing some intermittent problems with the zip drive- typically while loading a program from the disk to the mem or the Fadal we will either get a message saying :cannot detect baud rate or simply that it cannot detect the disk drive....???
    I am considering running a connection from the computer to the Fadal via the rs-232 port. My question is: Can I use the printer port from my computer?? I have read information that this can not be done due to voltage issues and / or the fact that the send and receive pins are crossed BUT I know a moldmaker who does run off the Printer Port with no problem. What is the correct way to do this????
    Thanks in advance.
    Dazed and confused!!!
    Dec 2004
    167
    Re: Getting g-code from the computer to the cnc
    Sir,
    If you are running a 32MP, there is no replacement for that Zip drive. Due to the control not recognizing or cooperating with the Zip drive, it has failed with no zip drive replacement available. I suggest you use the Calmotion USB interface with your machine and all problems are solved. Here is the part number for the interface: USBCNC-FAD88. Here is a link to more information about it: Calmotion USB Interface | Speed Shop | FadalCNC.com. Cost is $599 and in stock. Let me know if there is anything else I can help with.
    FadalCNC.com
  1. Replies: 51
    Last Post: 09-16-2020, 01:28 AM
  2. Replies: 5
    Last Post: 06-23-2014, 09:19 PM
  3. corel.hpgl > sheetcam.tap > pronterface.g-code > slic3r.g.code> ramps 1.4 > H-BOT
    By thesignworks in forum Uncategorised CAM Discussion
    Last Post: 05-25-2014, 02:11 PM
  4. What is the difference between an industrial computer and a normal computer?
    By Apples in forum Controller & Computer Solutions
    Last Post: 09-18-2008, 10:27 PM
  5. fast computer as server, slow computer as terminal
    By replicapro in forum Computers / Desktops / Networking
    Last Post: 07-01-2004, 08:05 PM
