Hi all,
I want to export g-code from Artcam to Mach3.
Does anyone have a post processor for this or do they have one form the Artcam drop down menus that they use and find works well with mach?
Blue Skies
mikie
Hi all,
Blue Skies
mikie
I always use any "g code". There are like 4
hi, i have a few of non toolchanging g-codes for ArtCAM. Are using metric or inches?
*Are you using metric or inches? Sry 4 typing error...
metric,
I actually sorted out my problem and found it was a scaling issue of the cad drawing and sent it through the faunic???can't remember the name exacly and it worked great
Thanks sunmix, if you don't mind, i would like to review a file that you have used that works, it gives me a comparison to the one that i generated.
I have one issue though, i changed my G0/G1 setting, removed it actually, and then added a feed rate to the line in-between the old G0/G1. When i tried running this, Mach3 didn't generate a drawing. Have you had any thing like this happen to you?
/Mikie
Mikie,
I'm not that sure, i think it happen a few times, although i didn't removed G0/G1 settings. I'm quite pleased with the mach post processors I'm having. BTW, I found out that it's hard to tweak Mach3 based on Mach2 settings especially the motor tuning section. I just couldn't get it right, so I'm using Mach2 for the moment. I might go for Mach3, but I don't have the time as I have some ArtCAM issues to settle.
In ArtCAM use the GCode inch and GCode mm Post Processors respectively for inch and mm
