im thinking about buying a machine that runs on m code. whats involved in changing it to g code?
G & M codes are used on an NC machine together
M codes are used to control the miscellaneous functions of the machine ie coolant ON/OFF, spindle direction + the start/stop etc
G codes are used to control the movement of the machine parts ie G0=rapid, X-123.456 = X axis address + co-ordinate
It is best to used the manuals that are supplied with the machine & control to fully learn those codes, as some codes do differ between machine makes, models, & machine makers
thank you i just now nothing about older machine is there any reason a 90s cnc machine wouldnt work with mastercam
Find a post processor in your post files for the controller on your machine.
Set up the machine definition for the configuration of the machine.
Obtain a programming manual for the machine / control.
Proceed with caution and modify post as required to get the output you need.
Im sorry for asking this question but i have been here conflicting opinions and was hoping to find the real anwser thanks ffor the help im going to pick itup saturday
