585,902 active members*
4,313 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Trying to Recover from a Hard Drive Failure
    Aug 2005
    88
    As stated about the hard drive failed. We got a new one from seimens and software from mag. The machine now boots and enables but I have a list of errors that pops up immediately and was hoping someone could be of help. Still waiting for seimens to call back.
    Run Off Information
    See cause (7)
    1.) The machine doesn not have a second Tool Drum. The spindle cannot be oriented to the required postion.
    2.)This Machine is not configured for a high torque spindle. The spindle align cycle looks for the presence of PR_C_TPA switch, not fitted on this machine.
    3.) The Z Axis tool change position has not been set
    4.) The Z Axis drum clearance position has not been set
    5.) The Z Axis second drum tool position has not been set
    6.) The tool changer has been set to diabled is this intended
    7.)The control option for Thermal compensation has not been enabled
    8.) The machine does not have a double arm tool changer
    9.) The C axis tool change position has not been set yet.
    For the record the tool changer is 21 slot single drum it is the older control so I think that the orientaiton is handled by the kollomorgan drive.
    Mar 2011
    462
    It has been a while since I have had to replace a hard drive like this, but if I remember correctly, the procedure when installing a new hard drive is:
    1) Install Hard Drive from Siemens (preloaded with Base and NCX level software)
    2) Load Cincinnti MAI software
    3) Restore Machine Dependent Data backup (M1Y-****.bck)
    4) Enter Option code from Siemens
    I would always then verify that the options content and machine settings are correct.
    Since the fault (7) indicates you have an option issue:
    Did you enter the Option Code from Siemens accurately?
    Was there any problem with the Machine Dependent Data restore process?
    Nov 2006
    418
    I think maverick is on the right track there, it sounds like you haven't loaded the m1y-** file. Please tell us you have a backup copy of the m1y file!
  1. EZTRAK DRIVE MOTOR FAILURE
    By premierpatterns in forum Bridgeport / Hardinge Mills
    Last Post: 10-07-2011, 10:06 AM
  2. HAAS VF3 hard drive or no hard drive
    By teal854t in forum Haas Mills
    Last Post: 08-18-2010, 03:27 PM
  3. Power Drive Failure
    By unionrim in forum Uncategorised MetalWorking Machines
    Last Post: 10-01-2009, 01:16 PM
  4. ez trak c drive failure
    By rsbbmw in forum Bridgeport / Hardinge Mills
    Last Post: 04-24-2006, 11:17 PM
