585,754 active members*
3,916 visitors online*
Results 1 to 13 of 13
    Dec 2011
    Hitachi seiki problems
    I have a Hitachi Seiki HC 400 with a Fanuc 15-m control. The machine was left off for an extended period of time. Upon start up it had an A axis servo alarm and overtravel of every axis in positive and negative. The machine doesn't even have an A axis. I turned off the axis in parametes and that alarm cleared but others will not clear. I found that the batteries had died and started to leak. I replaced the batteries and was able to locate a copy of all my parameters. I reloaded parameters and same overtravel alarms will not clear. I have had Fanuc service in on this and was told they could not help without wiring diagrams which we do not have. I am not getting anywhere with Mori support and I am really banging my head on this one. Please help!
    24220
    Are you getting + and - overtravel alarms at the same time? If so it is either a power supply or the ladder is not running.
    Can you display the ladder?
    Al.
    Albert E.
    Dec 2011
    The ladder is running and I have 24vdc from the power supply.
    May 2009
    106
    what alarms exactly , numbers etc ?
    Feb 2012
    5
    Issue with PLC Ladder upload HC-400 with FANUC 15M
    I have a Hitachi Seiki HC-400 with FANUC 15M control the machine has two control screens one in the front and one in the back for the PLC. The machine completely turns on but the PLC batteries were replaced as they were dead and now the PLC has lost all the ladder Diagrams. I have a hard copy of the ladder but it is very hard to load it manually. Can someone send me a soft copy of the ladder and also guide me what software do I need to compile and upload the ladder to the PLC?
    Please help!
    Aug 2011
    2517
    the ladder on 15-series is in ROM so you don't need the ladder. You may need PMC parameters though. they can be loaded manually if you have a hard copy.
    Feb 2012
    5
    A diff control
    fordav11 thank you so much for the prompt reply.
    But just wanted to bring to your attention that this 15M is
    configured a little different.
    The PLC is a Hitachi Seiki PLC
    and the control is a FANUC 15M
    and they both have their own individual ladder.
    Thus the screen in the back(Hitachi PLC) and the front(FANUC 15M)
    And yes we have already entered the PC parameters but the handshake between the PLC and the control will not be complete till the ladder is uploaded in the PLC.
    Feb 2009
    6028
    Fordav11, the hitachi machines Had there own way of doing things, so they would use multiple separate Plc controls for items like atc, magazine, even pallet change on some. With those Plc, they would use a lot of non standard custom built stuff. Difficult machines to deal with sometimes. I only know one good hitachi guy in my area, and it sure ain't me!
    Aug 2011
    2517
    ah I see. Totally non standard.
    Well you'll have more luck pushing sh*t uphill with a tooth pick than trying to get that one going unless you find someone with an identical machine.
    I suggest sell it on ebay as 'untested' and buy something more common
    Or contact Mori Seiki who now handle service for Hitachi Seiki machines (if you are lucky)
    May 2009
    30
    Re: Hitachi seiki problems
    some body can tell me how to change the programs from memory every time I try to do that gives me a message the write protect is on
    May 2009
    30
    the machine is a HC400 WITH 120 CUTTERS AND PALLET SYSTEM INDEX 4 AXIS I CAN TAKE CARE OF ALL THE ALRMS AND RUN FROM PROGRAM AUTO
    May 2009
    30
    AND IT HAS M11 FANUC CONTROL
    Dec 2009
    539
    Hello, this may sound simple,but is the write protect key in the right spot?
    John
  1. Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 05-05-2011, 04:12 AM
  2. Hitachi seiki 5ne
    By lapman in forum Community Club House
    Last Post: 09-16-2010, 06:27 PM
  3. Hitachi Seiki
    By 03clipse in forum MetalWork Discussion
    Last Post: 04-07-2010, 03:14 PM
  4. Hitachi Seiki
    By nicolae in forum Uncategorised MetalWorking Machines
    Last Post: 08-13-2009, 08:37 PM
  5. HITACHI SEIKI 25S/FANUC 10T PROBLEMS
    By conceptmachine in forum Fanuc
    Last Post: 04-21-2008, 02:29 PM
