585,977 active members*
4,180 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Weird tool compensation issues
    Apr 2008
    19
    Hi All,
    I am running a DMV 3016 and I program with MasterCam X.
    I use wear compensation on a contour cut of a rectangular piece. I have tool 1 as the rougher, tool 2 as the finisher.
    When there is no wear(d) compensation, both tools cut straight meaning if it's travelling and cutting on the x axis, there is no movement on the y or z axis. Visa versa. As soon as I put any sort of negative compensation, there is a problem.
    Example: when I put any (*-0.030" for example) wear(d) compensation on tool 1, it will cut along the left and right sides of the rectangle straight, meaning the y position is changing as expected but the x and z are static with zero movement. When it cuts the front and back edges, the x axis travels as programmed, but the y descends from .030 down to .000 instead of just compensating the whole .030" all the way through. Result is a tapered edge.
    Any idea why?
    Thanks for any help in advance.
    Dec 2008
    3109
    Cutter comp needs a lead in/out for it to work,
    Comp is taken up from the current postion ( line before the G41/G42 ), during the execution of the next line that has movement ( most have movement on the line with the G41/G42 ) --- this depends on the planes used ie G17 means comp is only on the XY plane, there is NO compensating movement on the Z axis
    so, if you select a rectangle with no lead in/out, the tool descends onto the profile, comp will be taken up on the next goto point ( giving you that taper ) - lead in /out moves must be larger than the value you wish to use in the control
    - if using comp "in Control", then the lead in/out values must be larger than the tool radius ( say 55% )
    Apr 2008
    19
    Thanks for the help. That was exactly what I missed. Problem solved.
    DaewooDMV3016
  1. Weird Mouse Selection Issues
    By eliot15 in forum GibbsCAM
    Last Post: 08-17-2011, 10:00 PM
  2. compensation issues
    By mattpatt in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-10-2011, 09:08 AM
  3. Funny (or weird?) behaviour with backlash compensation enabled (video)
    By FXC in forum Mach Software (ArtSoft software)
    Last Post: 02-21-2010, 11:17 PM
  4. Weird Z issues
    By Bigtoy302 in forum Waterjet General Topics
    Last Post: 12-24-2008, 03:24 AM
