Originally Posted by
More Coffee
I would like to put together a system that's variable speed, forward/reverse with a normally off switch.
no microcontrollers or computer interface.. analog manual control through a switch and potentiometer only
More Coffee
[B]
I'm going to drive the handwheel.A manufactured one that will also act as the sheave for the belt.My plan is to reduce the hand wheel 4:1 to the motor.
With a belt,,This well also allow more torque to the lead screw,but it will also slow the feed down.
I can step away from variable speed ,,if its easier, to just have two or three predetermined motor speeds.or stepping modes. as long as I can control the direction of the feed on a normally off,-----> on/off/on toggle switch.
I guess its a question of deciding what you want? so far your desires are a bit conflicting.
As already covered, if you want simple hand wheel control, the typical MPG puts out 100p/rev this could drive a step/dir amp directly but does not give any flexibility and relies on manual feedrate, a simple logic IC circuit could provide multiply or divide, but still manual.
If automatic indexing, 2 or 3 predetermined feed rates would be a bit restrictive, I would think?
The simplest automatic feedrate requires some logic, and although you expressed you don't want to go with microcontroller, I would be surprised if there was not a design out there based around a PicMicro or other controller that makes it simple and flexible.
Incidentally there are suppliers of Microchips that will pre-program them if you have the hex code from a design, if you want to avoid the cost of programmer etc. and just want to put it together.
Al.
Albert E.
