585,987 active members*
4,647 visitors online*
Thread: ATC Slide
Page 3 of 11 12345
Results 41 to 60 of 219
  1. #41
    Nov 2009
    724
    Looks Skookum Richard!:cheers:
    JTCUSTOMS
    "It is only when they go wrong that machines remind you how powerful they are."
    Clive James
  2. #42
    Mar 2009
    1114
    Very nice.
    Do you have any plans for chip guards?
  3. #43
    Oct 2008
    1632
    Thanks, Yes, it will be enclosed. It will look a lot like the Tormach ATC to a certain extent. I plan to have a cover with a retracting door. That of course only occurs after it's put on to see if it even works
    Richard
    Quote Originally Posted by Starleper1 View Post
    Very nice.
  4. #44
    Apr 2007
    2580
    Richard....
    Hey man you blaze the trail so we can all follow!! that is looking pretty sweet... I guess it is all made from what 1/4 inch plate? If you think about it the ATC is not really that complicated in actuality... It just takes a lot of work to make all the little parts. I still have to make the PDB before I can get to that but who knows when I will have a chance to do it. I will have to just watch you and enjoy your progress. I look forward to the day when I watch a video of an RF45 performing a flawless toolchange!! Keep on Keepin' on man... Peace
    Pete
  5. #45
    Mar 2011
    525
    That looks fantastic!
    Quote Originally Posted by rwskinner View Post
    All the fingers including the Nylon fingers machined today and bolted up. They grip pretty good. Maybe a little too good. Once I get everything together where I can test I can always slot or relieve the nylon some. They may be fine the way they are.
    Pictures....
    Kelly
    www.finescale360.com
  6. #46
    Oct 2008
    1632
    Thanks guys.
    Here is the detail the spindle shaft and housing. The housing contains two 15x31x9 Angular contact bearings and a .469-32 bearing nut.
    Attached Thumbnails Attached Thumbnails DSC02580.JPG   DSC02581.JPG   DSC02582.JPG
  7. #47
    Nice work Richard, good to see someone else actually making an atc and not just talking about it.
    Keep up the good work.:cheers:
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  8. #48
    Oct 2008
    1632
    Thanks Hoss. You provide most of the inspiration I have
    Richard
    Quote Originally Posted by hoss2006 View Post
    Hoss
  9. #49
    Richard
    Ah shucks, glad to help what little I can.
    Keep at it, the first successful auto toolchange makes all the design, machining, building
    and testing worthwhile, and it's COOL to watch.
    Hoss
  10. #50
    Oct 2008
    1632
    A little more progress
    I only have a couple hours each morning to work on this before I go to work so it's slow going. The motor drive and brackets are done. I have the slide built and I need to machine one more bracket to mount it to the slide.
    After that comes the more fun part, build the steel bracket that mounts the assembly to the column. I have it designed in CAD but I want make sure I cover all the adjustments, up/down, in/out, and tilt. Oh, I still need to get a small DA air cylinder and another 5 way electric solenoid valve.
    A couple more boring pics....
  11. #51
    Oct 2008
    1632
    I had time to knock out another little bracket that attaches the assembly to the slide rails. If your getting tired of all the pics let me know and I will stop attaching them.
    Richard
  12. #52
    Mar 2004
    1806
    PLEASE don't stop the pictures, they are giving me lots of ideas for the future:}) They also fill in some of the things that I don't quite understand from the discussion.
    Keep it up.
    Art
    AKA Country Bubba (Older Than Dirt)
  13. #53
    Aug 2008
    962
    I'm with Bubba .. keep the pics coming!
    You're blazing another trail here & there's LOTS of us who are keenly interested & will likely follow in your footsteps in the future.
    Document your progress well with pictures cause 'a picture is worth a thousand words ..'
    Gary
  14. #54
    Oct 2011
    Pictures Yeh - the more the better.
    Richard - thats a work of art that mate - well done.
    Looking forward to see details on controlling this - lots on info on this area please.
    Take it easy
    John
  15. #55
    Oct 2008
    1632
    Thanks for all the Kudos. I just knocked out the main bracket the linear rails attach to. Everything lined up and it all moves smoothly.
    During the Holidays and installing my Central Heat Pump inthe office/shop I got distracted and forgot to order my cylinder. So I ordered it today and the valve. That stuff won't be in until the end of next week.
    1 bracket left, mounting the entire works to the column. This will be the fun bracket and I will have to clamp and measure and then measure again. I held it up there and got a close idea and it looks like the CAD mach up of the mill is going be dead on. I mean it should be if I modeled it all correctly.
    Air Cylinder. It's a double acting 1-1/16" bore x 12" stroke cylinder that will be controlled with a 12 volt 5 way spring return solenoid valve. I did not see any cylinders like I wanted with internal cushions so I will have to devise a way for it not to slam open and closed. Needle valve is my first thought.
    Richard
  16. #56
    Nov 2009
    724
    That looks fantastic so far, I am looking forward to following in your footsteps.
    You could use something like this
    Or I even thought maybe some cheap RC car shock absorbers, you can adjust the damping rate with different viscosity silicone oils.
    Just a thought
    JTCUSTOMS
    Clive James
  17. #57
    Feb 2009
    2143
    Another vote for keeping the pix coming - more would be even better, and video is welcome too!
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
  18. #58
    Mar 2009
    1114
    You could use a flow control. Which is basically a needle valve with a built in check. Just make sure to get meter out not meter in.
    I'm curious why you chose the DCV you did, why not just a 4/2?
  19. #59
    Oct 2008
    1632
    I moved my control box to the right side of the mill. It has the Kill button, PDB Button and air solenoid inside of it.
    I took the cherry picker and hung the ATC and got some measurements.
    The square tubing is mounted to the column via spacers. One side of the square tubing has horizontal slots and the other side has vertical slots.
    I'm building a lightweight extension bracket to mount the slide to the square tubing. It's made from 5" wide x .125 flat steel. It will have the top boxed in with plate and a few stiffeners on the sides to keep it from flexing much.
    The Extension bracket will be all one continous flat with bends and only welded in one corner where it comes together.
    There will be horiztontal slots on the slide so I can move the entire thing closer or further from the spindle.
    If I can figure out how to unfold my sheetmetal bracket and alibre and print my dimensions on the flat I can fab this up pretty quick.
    Attached Files Attached Files
  20. #60
    Mar 2009
    1114
    Looks like a plan.
    If you can't get Alibre to flatten it, I can flatten it out in Solidworks for you if you want.
Page 3 of 11 12345
  1. SLIDE GIB PROBLEM...?
    By headsmess in forum Taig Mills / Lathes
    Last Post: 12-14-2010, 01:18 PM
  2. z slide
    By JackBlack in forum Want To Buy...Need help!
    Last Post: 01-30-2009, 01:51 AM
  3. SX3 -- Can't get the bed to slide off~~
    By krazatchu in forum Syil Products
    Last Post: 11-20-2007, 01:29 AM
  4. Looking for THK slide SR15T
    By Pplug in forum Linear and Rotary Motion
    Last Post: 07-17-2007, 05:15 AM
  5. misumi slide
    By Felipe in forum Mechanical Calculations/Engineering Design
    Last Post: 06-28-2005, 02:40 PM
