Looking for the correct schematic to build an RS232 cable. I know I have seen one posted here but cannot find the post.
Tim
Tim
Look in the operator manual for the machine. It is in there.
Mike
Ken Foulks
Here you are, Post #5.
http://www.cnczone.com/forums/haas_m..._programs.html
Thanks for all of the help!
I got it wired up on Sat. and its not working:
1. Made sure settings matched on machine/computer adapter/dnc software.
Is the program just dumped into machine memory? Do I need to tell the machine to recieve?
Tim
You do need to tell the machine to send or receive, as far as I can remember this is the sequence. Your program file in the computer needs % at the top and bottom.
Select the file on the computer but do not start to send it.
On the machine go to the List Prog screen and scroll down to ALL, type in the program name, Onnnnn, and push RECV RS-232.
Now start the send from the computer.
A 2008 machine using technology from the 60s. An ethernet card will allow much more powerful program transfers.
How-To: ENET | Haas
Ken Foulks
