I finally solved my V23 verify glitch / artefact / junk problem-- the one where tools don't erase correctly and it makes a mess of the verify screen. This fix also worked for a friend with BobCAD V24 that had the same problem. I don't know if this has been posted previously, but I've never found it searching.
The usual answer is 'reinstall your video drivers' or 'fiddle with graphics acceleration settings' and 'follow the nVidia setup FAQ'. Those never fixed it all the way for me.
Here's what did (Disclaimer: This may not work for you. Mucking around in Regedit can cause massive harm to your system, so be careful)
My system is Win 7 x64, with an nVidia GeForce 8800.
I was twigged to this by a reference in the Predator version log to some OpenGL registry settings (Predator Virtual CNC is used for Verify, and it is where the problem actually lies, not BobCAD)
So, open up Regedit, and search for 'OpenGL Settings' (no quotes, but include the space). You should find some keys like this:
Code:
OptimizeScreenUpdate REG_SZ ON
OptimizeToolErase REG_SZ ON
SwapCopyMode REG_SZ ON
I changed them all to OFF (I tried first turning ToolErase OFF, then ScreenUpdate OFF, but things didn't get clean until I turned off SwapCopyMode. I left the others off since it was working )
There are at least two sets of these that need changing, so keep searching and changing if needed until you get to the end of the registry, then give Verify a try.
