585,991 active members*
4,739 visitors online*
Results 1 to 2 of 2
    Aug 2006
    71
    Viper 200 Issue
    Hi Guys,
    (Larry I left a message on your machine)
    I am pretty much 95% done with my Matsuura retrofit, I plugged 12VDC power into the Viper 200 (I believe its a 200F), got a solid green light and a red blinking 4 times then off, then 4 times repeatedly, which based on the manual means there's no main power which is correct, I am trying to make sure the encoders are working properly like the instructions state.
    When I plug the RS232 programming cable onto the card, it basically kills the power (I can see a small spark in the RS232 white connector when I plug it in)
    Any thoughts? I was using an external bench top 12V supply for now, because the power supply I will be using to power the control power has not yet arrived.
    I also tried removing the ground pin on the RS232 connector, and then the card stayed on, but I could not get any communications with hyper terminal no matter what I tried.
    Any help is greatly appreciated,
    Thanks,
    Andy
    Aug 2006
    71
    Problem solved for now, Thanks for the Help Larry!
  1. New: Baby Viper 60
    By Larken in forum Viper Servo drives
    Last Post: 11-21-2012, 01:53 AM
  2. SD-1525 vs Viper?
    By erikjgreen in forum Vertical Mill, Lathe Project Log
    Last Post: 09-20-2011, 03:07 PM
  3. Cambam issue or Mach 3 Issue??
    By tracyranson in forum CamBam
    Last Post: 07-11-2011, 04:03 PM
  4. New 300 Khz Viper drives
    Last Post: 04-07-2010, 02:14 PM
  5. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
