585,977 active members*
4,670 visitors online*
Results 1 to 13 of 13
    Dec 2010
    634
    Cutting deeper than flute length
    What's the word on cutting deeper than your flute length? For a project I'm working on, I need to precisely profile some wood stock (hard maple) that is 2.80" tall and my 1/2" bit has a flute length of only 1.5". I've found extra long that has a 3" flue but the darn tool is 6" LOA. All I really need is 3" flutes on like a 4 or 5" shank.
    My bit supplier specs the bits at +.000 to -.002 in cutting diameter and I'm just wondering if I can do the full 2.8" depth with the 1.5" bit or whether that's going to cause problems. I can flip the stock but that leads to new inaccuracies.
    Any experiences with this?
    -Andy B.
    http://www.birkonium.com CNC for Luthiers and Industry http://banduramaker.blogspot.com
    if you can get enough stick out with your tool then the easiest thing to do would be to undercut the shank some with a bench grinder
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Dec 2010
    634
    Interesting idea. I got a PM to the same effect.
    So here's another idea - my tool is 4" LOA so, if I chuck it 7/8" into the collet, what about cranking it down to about 10k rpm and using sandpaper to bring the diameter down?
    The bit is carbide but, I only have to knock it down .001 to .002" to get the clearance right?
    -Andy B.
    #2320 or #2365 here. Vortex Tool: Pass by Spiral Upcut - Series 2300
    The actual price is under $100 when you add it to your cart.
    Quote Originally Posted by BanduraMaker View Post
    you do only need to knock it down a thou or two but chances are slim to none that the sandpaper will work , worth a try though if you don't have a grinder
    Dec 2010
    634
    My wife is very displeased with you Ger.
    -Andy B.
    Jan 2006
    2985
    Quote Originally Posted by dertsap View Post
    I would not recommend wrapping sandpaper around a router bit going 10k RPM. :nono:
    I would probably put a little harbor freight or dremel diamond burr in my dremel and do it by hand. If I had to get by.
    Matt
    Apr 2009
    5516
    They make necked endmills, where the shank diameter is slightly smaller than the cutting diameter... Bosch makes a 1/2" router bit with 3"+ flutes (I have one). Personally, I'd try and use or find a bit that will cut the full thickness of your work if possible...
    May 2007
    781
    Quote Originally Posted by louieatienza View Post
    The main reason for a necked endmill is that a 1/2" tool with 0.500" of flutes and 2.5" of neck that is 0.495" is a lot more ridged then a 1/2" tool with 3" of flutes.
    Used a lot in milling molds, customers always seem to design things so we have to reach deep into small places.
    Dec 2010
    634
    I broke down and bought the tool in Ger's link - hence my wife's nasty looks in his direction.
    I don't think that sanding would have been very dangerous to be honest though. I wouldn't be holding the sandpaper against the bit but rather doing it "shoe shine" fashion. If it got torn away, no big deal. Effectiveness is another matter.
    I think that with a 5" OAL, I should be able to clear the stock without too much difficulty.
    Thanks guys.
    -Andy B.
    Oct 2005
    2392
    You said it was a carbide bit? They are extremely difficult to shape using most tools, even on a bench grinder!
    HSS tools though are easy to grind to shape.
    Dec 2010
    634
    Which is why I'm not even going to try :cheers:
    -Andy B.
    Aug 2004
    54
    it may be to late for your project ,but i found this on ebay . OAL 4.6" CEL 3.0" CED o.5" SHANK 0.5" shank length 1.400" .its carbide tipped and probably made in china,but stocked here in ill. the seller is SUPER CARBIDE TOOLS ltem #130600019407 @$12.25 with $6.00 shipping .
    sincerely
    eigstein
  1. Capturing flute length (max depth of cut) in SprutCAM
    By gsnorcal in forum Tormach Personal CNC Mill
    Last Post: 12-06-2011, 03:34 PM
  2. Cutting deeper than cutting length
    By magudaman in forum CNC Tooling
    Last Post: 10-10-2011, 04:36 AM
  3. Cutting tubing to length on lathe?
    By ranchak in forum MetalWork Discussion
    Last Post: 07-20-2009, 02:06 AM
  4. Table length cutting problem?
    By Blacksunshine in forum WoodWorking Topics
    Last Post: 03-14-2008, 02:00 AM
  5. Help! Problem cutting steel with 3 Flute EM!
    By damae in forum MetalWork Discussion
    Last Post: 08-01-2006, 07:12 AM
