584,858 active members*
4,621 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > PlasmaCam > Z axis trouble while initializing?
    Dec 2011
    I just hooked up a new cutting torch to my plasma cam DHC2. I went with the hypertherm powermax 65. Everything went smooth with hook up, the plasma cam found the torch right away. When I proceeded to initialize the machine, it moved to home like always, but the Z axis will not find home. The machine moves to the corner of the machine with the x and y axis, but it will not move up and down on the Z. Hard to explain because if I slide the table out and move the Z axis down, then initialize, the machine picks up the torch with the Z moves it to home on the x and y, but then with not fully finish the Z axis positioning. If I put my hand on the Z axis motor I can feel it trying to move, it actually feels like it is moving extremely slow. ON the computer screen the initialize tells me that the machine is still traveling??? I am not sure where to go, or what to check? Any help would be greatly appreciated.
    Dec 2011
    I got it figured out. Thank you to everyone who took time to read.
  1. Mazatrol T32 initializing
    By terra103 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-13-2023, 06:33 PM
  2. Initializing servo amplifier Yaskawa CACR-IR30
    By ing.vic in forum Servo Motors / Drives
    Last Post: 09-02-2012, 10:31 PM
  3. Battery change and initializing position _ NL series
    By aidenkim in forum Mori Seiki lathes
    Last Post: 08-26-2011, 02:28 PM
  4. Y Axis trouble
    By alt.don in forum Xylotex
    Last Post: 09-15-2009, 06:49 PM
  5. Re-initializing Controller Software
    By Geof in forum Haas Mills
    Last Post: 03-18-2007, 06:54 PM
