I'm trying to constrain a circle to the origin, but it will not constrain. How I'm doing it is, I choose a circle, click the origin, type in the dimension. But it is still green. What do I need to do?
Thanks.
Thanks.
(I'm assuming you're using Inventor)
Create your circle, then make two dimensions, clicking the **center** of the circle and the origin. Once the dimensions are created, change them to 0 and your circle will be constrained to the origin.
you can also draw your circle center point on the orgin, select the center point and click the lock icon in the constraints menu
