585,712 active members*
4,132 visitors online*
IndustryArena Forum > Hobby Projects > I.C. Engines > Atkinson Cycle engine
Results 1 to 6 of 6
    Sep 2009
    12
    Here is some video of my Atkinson I built. It was a fun build I had wanted to build one for a long time and finally got around to it. I would like to build the Atkinson differential engine to keep this one company (maybe).
    [ame=http://www.youtube.com/watch?v=SLTwe-hdpvY]atkinson engine - YouTube[/ame]
    Jan 2007
    76
    Nice job...runs sweet.
    Built one here myself, much the same only did castings. My flywheel is not quite as big diameter as it was all I had at the time and so low rpm is not quite so low as yours.
    Jan 2007
    76
    Video here...........
    Atkinson.mp4 - YouTube
    Don't know how to post video like you did...doesn't seem to be any instruction on how to do anywhere
    Sep 2009
    12
    Update I've ran my Atkinson a few hours and the rings are getting seated pretty good. It has become a pretty good runner and can idle way down and starts almost all the time with just a little flick of the fly wheel.
    [ame="http://www.youtube.com/watch?v=KUsfIq6Iy_0"]My Atkinson after a few hours of run time.[/ame]
    Aug 2012
    17
    Are these Listeroid type motors? Very cool little units. Thanks for sharing. Wish, the Listeroid where still around. Was trying to get one, then the EPA did that whole Tier II thing. Great job
    Take care,
    Steve
    Jan 2007
    76
    Quote Originally Posted by SB123 View Post
    Take care,
    Steve
    These engines are a bit different to the usual 4 stroke.
    To begin with, they have linkages attached to the main crank which allow the four cycles of the 4 stroke to be completed in one revolution of the crankshaft. This then allows the cam to be fixed to the crankshaft, i.e. no requirement for 2 to 1 reduction gear drive.
    The way in which the linkages and pivots are arranged allow for an "efficiency" system to come into play.
    Power stroke and exhaust stroke are both "long".
    Induction and compression strokes are "short".
    i.e. piston moves different amounts for the type of stroke.
    Quite an achievement for the times when no computers were available to calculate or simulate the actions, just an idea and a slide rule, pencil and paper.
    Doc, if you plan to do the other engine, look very closely at any plan as there are problems with the designs. Very little compression ratio and timing just does not seem correct for the placement of the spark plug. Friend of mine is re-drawing plans and setting up on a simulated CAD to try to iron out the problems.
  1. Search drawing from free piston engine ->stelzer engine
    By Enginetuner in forum I.C. Engines
    Last Post: 12-20-2022, 11:13 PM
  2. 6 cycle engine
    By doc0455 in forum I.C. Engines
    Last Post: 12-20-2011, 10:41 PM
  3. CYCLE 83: pecking cycle with deepened starting point
    By Bastida in forum SIEMENS -> GENERAL
    Last Post: 12-18-2011, 04:25 PM
  4. sequential cycle rotary engine (SCRE)
    By dr kingston in forum I.C. Engines
    Last Post: 03-22-2007, 10:34 PM
  5. Atkinson cycle engine
    By mark c in forum I.C. Engines
    Last Post: 01-21-2007, 04:50 PM
