586,000 active members*
4,922 visitors online*
IndustryArena Forum > MetalWorking Machines > Mikinimech > VFD and AC Motor replacement project
Page 1 of 17 12311
Results 1 to 20 of 337
    Dec 2008
    263
    I decided to go ahead and start a thread for this. I finally decided to just get rid of the BLDC and Mikini electronics as I have had a ridiculous amount of trouble with the Mikini electronics over the last three years.
    And now that the spindle is actually working I find it is entirely gutless in the low end of the RPM range. So I finally decided there was no other real choice than to gut the Mikini electronics and replace them with parts I know will actually work.
    So I have decided to go with an AC motor and VFD setup. And to replace the Mikini breakout board with a more standard CNC4PC bob. So here is what I have so far.
    2HP Hitachi sensor-less vector VFD
    http://www.driveswarehouse.com/Drive...200-015SF.html
    2HP Inverter duty motor
    Y368 Products
    CNC4PC C23 BOB
    CNC4PC
    One problem I will run in to is that the new motor weighs 45lbs. The BLDC motor on the machine weighs 22 pounds as I just weighed it. I have one of the original 1610Ls and it does not have a gas strut on the Z axis. So I am going to have to add a gas strut to the Z axis. Anyone have one on their machine and want to post some pictures of how it is mounted so I can get some ideas on how to mount one? Measurements and or specs for the strut would be useful too.
    Anyone have any input on pounds of force for the strut?
    Sep 2010
    529
    I have purchased the gas struts for other things, a good source is Guden Hinges and Industrial Hardware: Guden Home Page, they have them from small poundage all the way up to 250 pounds of force. They also have mounting hardware.
    Feb 2009
    2143
    Why "step down" to a 2 hp motor?
    Are you planning to retain the "manual mode" use of the machine, or just bypass all the Mikini hardware and control straight from the PC?
    FWIW, here is a solution I was looking at.
    Motor: http://www.automationdirect.com/adc/..._to_30HP)/Y541
    Driver: http://www.ebay.com/itm/3-HP-Sensorl...#ht_6204wt_910
    These would net you a 3 hp power, and a top speed of 5400 rpm. Huge benefits over the system you spec'd, I think... It would cost about twice as much, though...
    I am looking at going a different direction now, though. I have found a Vector Drive that will work with the existing BLDC motor on the Mikini. I do plan to order it and see how it goes. Hoping it will be a "transparent" change, but give significantly better control/power out of the motor... I have found the drive I want online, but have had a hard time finding a way to order one so far. Plan to look in to it over the Christmas break...
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Dec 2008
    263
    It's not stepping down at all. This spindle does not put out 3 HP at any range that is usable for steel or drilling with larger diameter drills. I suspect it does not put out 3 HP at all. That sticker is just a sticker put on in China as far as I am concerned. I have a real mill with a real 3HP AC motor and VFD and there is no comparison this spindle is a gutless wonder and the real 3HP spindle on my other mill never quits no matter what I have thrown at it. I mean this BLDC stalls out on a .50 DOC with a W drill in 6061 at 1000 RPM. That's a cut the X2 mini mill will make without complaint.
    Look at the Tormach's 1.5HP and VFD and read their paper on VFD versus BLDC they are closer to the truth. I honestly don't think this is a 3HP BLDC period regardless of the drive used it's a very suspect Chinese 3 HP.
    My goal is to get rid of the Mikini electronics all together as they are crap. Why would I try to keep them they are not at all reliable or good.
    So the reason I did not go to 3HP is weight and AMPS it would be about 20 amps just for the motor and the motor would weigh close to 70 lbs. Also a real 2 HP will be just fine you will see. The driver you point to is a three phase input FYI. Mine keeps the single phase and the same total 20 AMP input requirement and keeps the weight to a more reasonable 45lbs even at that I am doubling the weight of the motor.
    Feb 2009
    2143
    Wasn't trying to piss in your Cornflakes there!
    The drive I linked can be spec'd for single phase as well. I called and spec'd out all the parts from them and discussed the application as well.
    I am sure your solution will work, was just curious about some of your specifics and the rationale at why you decided on those specific parts. Please keep us all updated!
    Dec 2008
    263
    You didn't piss in my cornflakes. What irritates me is the lack of guts of this spindle, not you, so don't misunderstand. Sorry if I came off that way.
    I thought a lot about a 3HP spindle but I don't think it really makes sense power wise, weight wise, or even requirements wise for this size of machine. As I said I don't think we are getting anything like 3HP now.
    So on the drive you specced if you derate it for single phase you wouldn't get 3HP out of it. Hitachi makes a single phase 3HP VFD see here http://www.driveswarehouse.com/Drive...200-022SF.html but it requires 22 amps all by itself. I don't see on that posting what the amps required for that drive are.
    Cheers, Allen
    Quote Originally Posted by mcphill View Post
    Feb 2009
    2143
    You are probably right that 2 hp is more than what we have now, and more than enough for the machine... The Lenze drive is sized for the application specified. I think they actually use the 5 hp version and derate to use it for 3 hp when you supply single phase power. Again, I had a pretty lengthy call with the place where I was going to buy from.
    Here's a link to the "right" part: AC Tech SMVector Drive - ESV222N02YXB - 3.00 HP - 9.6 Amp - NEMA 1 Enclosed | | Precision Electric, Inc.
    They state 9.6 Amps output - don't see a supply rating...
    Dec 2008
    263
    5HP derated to 3 might work depending on the input requirements.
    I think that is what is on my big mill a 5HP Yaskawa VFD derated to 3HP for single phase and that can run on my 20 amp circuit. But it does not have any servos or steppers well it has one servo on the X axis.
    But when I look at it and if you were standing next to me here looking at it you would say oh that motor is not going to fit on top of the Mikini. Take a look not sure if you can get the scale from this picture. But this is a 3HP AC motor.
    Aug 2010
    599
    Needless to say, I'm following this thread with extreme interest. Mike, are you going to try and use the same motor and just replace the drive?
    24221
    I have found a Vector Drive that will work with the existing BLDC motor on the Mikini. . I have found the drive I want online, but have had a hard time finding a way to order one so far. ...
    Do you have a link to the drive, I am curious to see a VFD drive that works with a BLDC motor?
    Al.
    Albert E.
    Feb 2009
    2143
    Quote Originally Posted by SWATH View Post
    My ideal solution will be just a drive swap, with no changes to any other parts or functionality impacted... I don't know if I can achieve this or not, and I am at this point only "hoping" that a new drive will result in a more usable machine. If it doesn't work out I will go for an AC motor and drive swap, and likely nuke all the manual Mikini functions... The biggest downside for me with that is that it will take longer - and time is one resource I have NO WHERE near enough of!!!
    Feb 2009
    2143
    It took me FOREVER to find it again yesterday, Parker's site is atrocious!
    Parker Hannifin, Compumotor Division, North America - A Complete Family of Motion Control Products
    http://www.compumotor.com/new_ulm/pd...out%20asrd.pdf
    I have yet to actually discuss the application and get the pricing for this option, so I am not 100% sure it will work yet...
    Dec 2008
    263
    Anyone with a V2 machine want to take a couple of photos of the gas struts mounting setup so I can get an idea for that part of the project?
    24221
    I am just curious how they fit all that into such a small package, where just about all other drive manufacturers need the room to put the large power supply usually associated with VFD and BLDC DC power supply?
    Sensorless BLDC has been around for a while but that IS small for a VFD of that capacity?
    It resembles more the appearance of a 3ph slow start.
    Be nice to see some working applications?
    Al.
    Albert E.
    Feb 2009
    2143
    I am not home right now or I would give you exactly what you want, but maybe these will do?
    Feel free to poke around to see if there is something else useful:
    Mikini 1610L | mcphill | Fotki.com, photo and video sharing made easy.
    Dec 2008
    263
    Thanks Mike that is helpful.
    If anyone has the length and force of those shocks that would be helpful too.
    Aug 2010
    599
    The main black tube is 13in. and ~27mm in diameter, the bright metal piston extends 12in. and is ~16mm in diameter. I don't know how far the slender black piston extends but it makes up the difference when the Z is all the way up. The total extended length from center of ball joint to center of ball joint when Z is at maximum height is 31.25in. Don't know what the weight is, Phil would probably tell you if you asked him. Then you can simply take the weight difference between the 22lb BLDC and the new AC motor and add that to the weight rating of you struts. McMaster-Carr also has a nice selection of gas springs: McMaster-Carr
    Dec 2008
    263
    Thanks swath that's what I needed.
    Dec 2008
    263
    Well the motor is here.
    Feb 2009
    2143
    Unless I am mistaken (due to the perspective), Dat's a BIG motor!!!
Page 1 of 17 12311
  1. Replies: 1
    Last Post: 03-06-2013, 05:19 AM
  2. Replacement Motor Brushes For Sherline Mill AC Motor
    By Lessons in forum Benchtop Machines
    Last Post: 07-17-2010, 02:34 AM
  3. Replies: 12
    Last Post: 07-11-2010, 03:04 AM
  4. replacement motor for PML&Kollmorgen DC Brush Servo Motor
    By fymroger in forum News Announcements
    Last Post: 10-24-2008, 09:36 AM
  5. Possible replacement motor for an X3?
    By tauntdesigns in forum Benchtop Machines
    Last Post: 05-17-2008, 04:24 AM
