585,886 active members*
6,164 visitors online*
IndustryArena Forum > MetalWorking Machines > Mikinimech > VFD and AC Motor replacement project
Page 6 of 17 4567816
Results 101 to 120 of 337
  1. #101
    Dec 2008
    263
    It might, I got some new home switches in this week. I am going to work on getting them fitted and working today. Then after that it's work on wiring up the spindle itself. Here is a picture from last week. This is in the machine now and the new stepper drivers are working well. I will try and post another update this weekend.
    Quote Originally Posted by mcphill View Post
    Allen, I think we are all ready for a video of the machine up and running the new spindle, with now issues... Will that happen this weekend?
    Best of luck to you and keep us updated!
  2. #102
    Feb 2009
    2143
    Allen,
    How's that update coming? Waiting patiently!
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
  3. #103
    Dec 2008
    263
    Progress report, I got the Y and Z axis home switches mounted and working Pretty easily. The X axis was another matter entirely. I have about two days of fiddling in to that one switch. The problem is the new switch is not lining up with metal flag. And nothing is easily accessible or visible on that axis. The switch has gotten ripped off 3 times and the screws got sheared. So I had to go back to the drawing board on that one. I am going to try replacing that switch with a hall effect switch and magnet.
    I have been out of town three weeks now. The first two weeks on business and this last week on vacation in Hawaii. So that has slowed progress a lot. I am hoping to take a whole week off in two weeks to finish the project.
  4. #104
    Dec 2008
    263
    Video update
    Progress at last. That one X switch took far too long. Spindle is turning again getting close.
    [ame=http://www.youtube.com/watch?v=DLccuCNuCXA]Mikini 1610L AC motor and VFD replacement project Video 6 - YouTube[/ame]
  5. #105
    Jun 2011
    695
    Hey if you have time could you document how you hook up the coolant to the BOB I have a similar board C11T and would like to run mine through the board also if you could show VFD hook up I don't have the Hitachi but any real world connection would probably help.
    Build is really coming along and looks very professional. Spindle sounds really smooth I bet it will make some nice smooth cuts.
    Hurco KMB1 Build
    Wholesale Tool 3in1 conversion
    C-Constant
    N-Nonworking
    C-Contraption
  6. #106
    Jul 2006
    367
    Looking good Allen!!!!! I really like how the motor sounded at full RPM. I don't think you'll have any issue of the motor faulting
    Once, I get caught up with some customers, I'll be doing the same retrofit. My disappearing screen issue is coming back and I just don't want to waste time with the Mikini electronics anymore.
    As for hooking up the VFD to the c23, I have a c11 on my lathe and I'm pretty sure i used both relays to run the vfd....I'll check tonight. I think one relay was used to stop and start and the other was for reversing. To run the coolant pump, I bought a relay board from Arturo (cnc4pc) and just hooked it up to an output pin.
    Lastly, you'll really enjoy those digital drives when in actual use....they are really nice.
    pete
  7. #107
    Feb 2009
    2143
    Looking good, Allen, thanks for the update! Really interested to see how the VFD does on lower speed cuts in steel - that is my main issue with the system right now. Cutting high speed in aluminum works fine, but it just has no guts when trying to go slow...
    The steppers sound REALLY good too, on the new drivers. Those are the original stepper motors on the axis drives, right?
    Finally, I see your have an older machine with the metal front door. My newer one is all plastic. I believe the X-axis switch on my machine is already located where you put yours...
  8. #108
    Dec 2008
    263
    I will document the coolant hookup. Its pretty straight forward just run the AC hot through the relay NO side. I will also document the programming and wiring for the VFD. Thanks for the kind words.
    Quote Originally Posted by FannBlade View Post
  9. #109
    Dec 2008
    263
    Thanks Pete, I think your right about the relays I remember seeing that on the instructions now. Wish I coul work on the mill this evening but I am off to Dallas for work unfortunately.
    Quote Originally Posted by slowtwitch View Post
  10. #110
    Dec 2008
    263
    Thanks mike, yes those are the original steppers the new drivers are sweet.
  11. #111
    Mar 2009
    199
    Alan,
    I would like to know the total cost of the parts for this project if you don't mind sharing.
    Chris
  12. #112
    Jan 2006
    58
    Looking great Alan. I'm about to start ordering parts to begin the transformation of mine into a Mik-Allen.
  13. #113
    Dec 2008
    263
    Quote Originally Posted by howecnc View Post
    Alan,
    Chris
    Hi Chris,
    No problem here are the costs so far not including shipping
    Marathon Micro Max Motor 2HP Y368 429.00
    WJ200-015SF Hitachi VFD 283.00
    KL-8070D Keling Digital Bipolar Drivers (not neccessary but better) 120 x 3
    360.00
    CNC4PC C23 BOB 198.00
    CNC4PC MPG 2 (also not necessary) 198.00
    C22 pendant interface board (also not necessary) 29.65
    Honeywell 785-HOA6990-T51 limit swithes 41.0
    Various wiring and cabling stuff ~100.00
    total ~1440.65
  14. #114
    Dec 2008
    263
    Quote Originally Posted by Sweeney View Post
    Thanks man, we do need to come up with a new name for it franken-mikini? :cheers:
  15. #115
    Dec 2008
    263
    Video update number 7
    The spindle is now under Mach control
    [ame="http://www.youtube.com/watch?v=ZCj3UDHdVCg&feature=player_detailpage"]http://www.youtube.com/watch?v=ZCj3UDHdVCg&feature=player_detailpage[/ame]
  16. #116
    Jun 2011
    695
    Thank you for the Vid I watched it earlier this morning. Makes a whole lot more sense when I can "see" the wiring.
    Thank you!!!
    Hurco KMB1 Build
    C-Constant
    N-Nonworking
    C-Contraption
  17. #117
    Jan 2006
    58
    Thanks for the update, Allen! Looking good...
  18. #118
    Jul 2006
    367
    This is getting exciting!!!!!!
    pete
  19. #119
    Mar 2009
    199
    Lets see some chips being made already!
  20. #120
    Dec 2008
    263
    One small problem, actually one big problem. I can't get to the Mikini right now because this showed up yesterday.
    Going to have to get it in place and everything back in place today.
  1. Replies: 1
    Last Post: 03-06-2013, 05:19 AM
  2. Replacement Motor Brushes For Sherline Mill AC Motor
    By Lessons in forum Benchtop Machines
    Last Post: 07-17-2010, 02:34 AM
  3. Replies: 12
    Last Post: 07-11-2010, 03:04 AM
  4. replacement motor for PML&Kollmorgen DC Brush Servo Motor
    By fymroger in forum News Announcements
    Last Post: 10-24-2008, 09:36 AM
  5. Possible replacement motor for an X3?
    By tauntdesigns in forum Benchtop Machines
    Last Post: 05-17-2008, 04:24 AM
