Thanks for your thoughts. The 1/8" materials are two: the 40" x 1/2" x 2" C- channel gets the slots; then 1 1/4" and 1 1/2" x 1/8" square tube gets holes, and also 1/4" x 2" flat stock get's multiple holes; all of which are 11/32".
[That should be a lot easier to hold down than the 1/8" flat stock I thought you meant.]
I plan on using Cobalt tooling if I can get it and, if not, then I'll use carbide. My concern about this would be my next question.... in the tooling setup it asks for shank size and tool diameter, and I'm not sure which aspect of the mach3 utility would be affected; max rpm? Feed rate?
[I'm not too familiar with "LazyCAM", but I'd assume that was to calculate offsets.]
Since you mentioned multiple passes, I was wondering if I can't use a full size tool with a reduced shank, which would surely reduce the time req'd. to do each part. The collet size on this machine is just a tad over 1/4" max...
[That might be hard to find. It's a lot more common to see endmills with shanks bigger than the flutes than the other way around.]
a C11 I believe it is. On the C-channel I plan on having 5 or 6 parts on the table, and I'd be able to clamp down each end... same for the drilling of the flats and Sq. tube. Someone who used to make these parts used either mist-type cooling or two drops a minute of coolant.
I've been cramming on using Mach3 and Rhinocad/cam, since it's been so long since I used g-codes that it's like I never did it at all.
[It's like riding a bicycle - it'll all come back to you once you're aboard...]
I'll be getting the parts soon so I can take accurate measurements of slot/hole locations and try and draw them up on Rhino. I'll be pressed for time to get all this working as it should because I have to have the first run of parts cut, machined, welded and shipped by the end of March. I've considered paying someone to help with that (g-codes for the parts), but there's no-one around this small town that knows much about it. That would be great because I could see the code for each part and learn at the same time.
[It's not that hard, especially considering that your parts aren't very complex. You could probably code it by hand, but with Rhino/RhinoCAM it will be a lot simpler. If you haven't bought the software yet, I can get you a good deal on it. And Mecsoft has excellent tech support to walk you through any tough parts.]
I have the free cad utility called CamBam, too, but that's only a last resort at this point, as I'd rather use Rhino.
You can see the parts I have to make at:
Welcome to Advanced Technique Fireworks Home on the Web Click on "Racks" at the top, then "Aluminum Racks." This is new venture for me but it is in line with my main business of designing and building trailers for people that shoot display fireworks. I can design/build most any other kind of trailer, too, but as the name implies, pyro trailers are the main reason I started the business.
StarFire Trailer Systems -- Made in America
