585,969 active members*
4,358 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > visualmill post for cent6 vm15
    Feb 2011
    41
    Red face visualmill post for cent6 vm15
    I need a little help figuring out an issue I have with the post for my vm15 cent 6
    1) for every tool change I cant get the tool # offsets to post . If I understand this right , you need this (G43H0 D01)for the tool change with a tool changer ?
    T5M06
    S6000M03M08
    G43H0 D01
    2) At the end of the program the head crashes to the table . I'm thinking it has to do with the G00Z00 in this part . What I have been doing is , erasing this end lines and inserting a tool change to stop it from crashing . It works , but is there something I should change in the post processor ? same with the tool offsets .
    G40G49M09
    G00Z00
    G00X0Y0
    M05M30
    END
    I'm kinda learning the hard way but getting there ,I think
    Steve
    Sep 2010
    529
    Steve,
    You need your tool offset call to have a corresponding offset number, not just H0, so your G43 line should look like this:
    T05M06
    S6000M03M08
    G43 H05 D05
    Now, you don't always have to have the offset and diameter numbers be the exact same as the tool number, there are cases where you might use two different offsets on the same tool, but.... in general, you always number the D and H values the same as the tool number.
    Once that specific tool offset is active, then at the end of each tool, and at the end of the program, you put in a G40G49Z0M09 line.
    Jan 2004
    3154
    Make sure that you put the offset # into the callout during your tool creation.
    IDK your control but you may need a G53 or G28 in your end code.
    The post processor is 100% customizable in VM
    www.integratedmechanical.ca
    Feb 2011
    41
    Quote Originally Posted by Brian L View Post
    Steve,
    T05M06
    S6000M03M08
    G43 H05 D05
    thanks Brian , I've been editing the G43 line after I post . The end of program was the main concern
    Quote Originally Posted by DareBee View Post
    How do you change the tool change in the post processer ? I can see where to change the end of program .
    Steve
    Jan 2004
    3154
    Change it in the tool change tab
    I would expect the last line of your first load tool macro to look like this
    [SEQ_PRECHAR][SEQNUM]Z[NEXT_NONMDL_Z]H[TOOL_ADJST_REG]
    this line does NOT include D offset and you would have to add it as well with the [TOOL_ADJST_REG] behind it.
    You may need to play with the other tool change macro as well.
    My machine holds the [TOOL_ADJST_REG] as modal for subsequent changes
  1. Milltronic Vm15 Powermill Postprocessror Need
    By ehsan.amouzegar in forum Milltronics
    Last Post: 03-27-2011, 05:27 AM
  2. SprutCAM vs VisualMill
    By BanduraMaker in forum SprutCAM
    Last Post: 03-05-2011, 02:00 PM
  3. Help Visualmill
    By rtardio in forum Visual Mill
    Last Post: 10-29-2010, 12:56 PM
  4. VisualMill Post G-Code is Metric, Why ?
    By ringram2077 in forum Visual Mill
    Last Post: 09-25-2007, 06:48 AM
  5. TurboCad and VisualMill 5
    By ringram2077 in forum Uncategorised CAM Discussion
    Last Post: 06-15-2007, 03:58 PM
